TDIDog's Avatar
Clicking sound in drivetrain
Has anyone had this happen? When I take off I get a click it the drive train. Then when I reverse I get it again. Only happens once till I change forward to reverse. Wonder if it is a CV joint or lose axle. Any other ideas?
Thanks for all input.
jack
Old 08-03-2011, 09:04 AM
Cv
Tell it like it is or don't tell it at all.
Old 08-03-2011, 09:08 AM
na2ub's Avatar
Could be a loose caliper / brake pad - clicks as it moves to one side, everytime you change direction.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 08-03-2011, 09:17 AM
Max Sluiter
Flieger's Avatar
Check the CV joint bolts. They are known to come loose unless torqued perfectly (without getting any grease from the CV joint on the threads).
Old 08-03-2011, 10:52 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
CV joint bolts. Check them ASAP.
Old 08-03-2011, 11:06 AM
TDIDog's Avatar
I will,
Thanks you guys. Had a Porsche mechanic put my tranny in recently, but never know. Not worth not checking.
Cheers
jack
Old 08-03-2011, 12:09 PM
pete3799's Avatar
Also check the torque on your lug nuts.
Pete
79 911SC RoW
Old 08-03-2011, 12:23 PM
TDIDog's Avatar
Well I checked the axle bolts & lug nuts. They are all tight. I need to be more specific in that it would only click once in reverse, then once in forward. not a continuous clicking. Could it possibly be my LSD? I just had the tranny rebuilt & the diff clutches are all tightened up.
Thanks again.
Old 08-03-2011, 10:46 PM
Driver
Noah930's Avatar
My car does that, too. CV bolts are torqued to spec. I've written it off as normal.
1990 Black 964 C2 Targa
Old 08-03-2011, 10:52 PM
mikesride's Avatar
mine does the same as well have checked all the logical things.....will be watching this thread closely
I've driven alot of crap to get here man!
Old 08-04-2011, 03:43 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
yes check the cv bolts
i had one backing out and made the same sound as a rock or nail in the tire. it was half way unthreaeded and hitting the e-brake cable where it comes into the back of the hub. all the others on that side were below torque. the other side was all to spec.
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 08-04-2011, 04:30 PM
