NEWFIE 69 911E's Avatar
Smog pump delete - simple air injector plug!
Self-explanatory
Npt plugs obtained at Princess Auto, less than $2 each.
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 08-07-2011, 07:06 AM
76 911S Targa
Our host sells the plugs for around $1.85 each but they replace the entire part you show, screwing directly into the cylinder head. Your solution avoids the danger of breaking off the air injector in the head. Clever. I have removed the air pump but I haven't worked up the courage to remove the air lines yet. Using your method I could do it in stages. The air lines are a pain because they block the steam cleaner from degreasing the nether reaches of the engine.
Old 08-07-2011, 08:41 AM
RETIRED
Joe Bob's Avatar
I've heard Ace hardware plumbing caps will work.
2012 ML350 3.0 Turbo Diesel
Old 08-07-2011, 09:02 AM
Yes, I did see that our host sells the required plugs. I order parts regularly from our host, but I needed to acquire the plugs fast / locally.
I needed to remove the air lines in order to replace the leaky oil return tubes, but it was quite easy; some fasteners were seized so I carefully cut the tubes with a small cutting disc on my Dremel.
1969 911E Coupe
Old 08-07-2011, 11:07 AM
Oh Haha's Avatar
That's exactly how I plugged my air injectors. Mine were free as I had them in my "junk" box from a previous project.
Pacific Blue
Wayne
Old 08-07-2011, 07:10 PM
