				Smog pump delete - simple air injector plug!
			Self-explanatory
				  ![]() ![]() Npt plugs obtained at Princess Auto, less than $2 each.
	In stable: 1980 911SC Targa RoW Guards Red 1969 911E Coupe  |
			 76 911S Targa
			Our host sells the plugs for around $1.85 each but they replace the entire part you show, screwing directly into the cylinder head.  Your solution avoids the danger of breaking off the air injector in the head.  Clever.  I have removed the air pump but I haven't worked up the courage to remove the air lines yet.  Using your method I could do it in stages.  The air lines are a pain because they block the steam cleaner from degreasing the nether reaches of the engine.
			 RETIRED
			I've heard Ace hardware plumbing caps will work.
	1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel  |
 I needed to remove the air lines in order to replace the leaky oil return tubes, but it was quite easy; some fasteners were seized so I carefully cut the tubes with a small cutting disc on my Dremel.
			That's exactly how I plugged my air injectors. Mine were free as I had them in my "junk" box from a previous project.
	1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne  |
