cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
CV bolts come loose
Is there any down side to using Loctite on CV bolts?
Found a cv bolt on my driveway this weekend even though I have been pretty good at checking them when under there. Consider myself lucky for having it fall off on the driveway of all places. I have star washers on the ends but they obviously don't work.
Thanks,
Chris
73 911 E
Old 08-15-2011, 11:01 AM
r_towle's Avatar
You need to clean out the threads in the flange with a good cleaner to make sure the loktite does something valid.
You can also get race wired bolts and tie off the heads...just more insurance.
Use new washers when you put the bolts back in.
Rich
Old 08-15-2011, 11:05 AM
cmcfaul's Avatar
Whats the correct washer to use?
Old 08-15-2011, 11:07 AM
I believe the name of the washers are Schnoor.
Old 08-15-2011, 11:48 AM
Packy's Avatar
Rich
Use schnoore washers for sure, and +1 on safety wire. I rebuilt my CVs like 3 times before I decided that the ridiculous amount of cleaning wasn't worth it. Safety wire makes is so much easier IMO.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 08-15-2011, 12:01 PM
cmcfaul's Avatar
How do you attach the safety wire? Those bolts are made from really strong steel. Can they be drilled easily?
Those look like the washers I used from Home Depot. Do they have to come from the Porsche gods?
Chris
Old 08-15-2011, 12:17 PM
AutoBahned
RWebb's Avatar
safety wire is not needed if the correct fasteners are installed and done so properly
safety wire will NOT maintain the correct torque on the faces of the CV assemblies
Schnorr is the correct washer - always use new - they are NOT at Home Depot
carefully clean both male and female threads with brake cleaner & Q-tips
do a search to find a thread that explains it all
Old 08-15-2011, 12:42 PM
MBruns for President
JeremyD's Avatar
Brake cleaner - q tips - correct torque with new Schnorr washers or go with the stage 8
World's Best Locking Fasteners & Locking Nuts and Bolts STAGE 8
you don't want a CV joint coming loose - makes a hell of a mess.
Old 08-15-2011, 12:58 PM
burgermeister's Avatar
schnorr washers are available from mcmaster-carr for a very reasonable price. As is most other metric hardware.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 08-15-2011, 01:52 PM
Grady Clay's Avatar
While long, this thread will have everything you need to know.
Reconstructing Constant Velocity (CV) Joints
This is worth studying end-to-end.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-15-2011, 02:08 PM
Packy's Avatar
I drilled the bolts for the safety wire. It is just a back up. RWebb is right that the safety wire won't keep the torque spec, but it prevents them from backing out more than a 1/4 turn or so. It isn't fun when the CV bolts come out going 100 mph, ask me how I know.
Toluca Lake, CA
Old 08-15-2011, 02:55 PM
gtc gtc is offline
abides.
gtc's Avatar
I'm a recent convert to these Nordlock washers. I've used them on my car and another Pelican's, and haven't seen any loose bolts since. They are also reusable, whereas Schnoor washers are not. The only caveat is that they are a bit thicker than schnoors - 2.5mm or so.
Graham
1984 Carrera Targa
Old 08-15-2011, 03:04 PM
I have the other car with nordlocks, and haven't had a problem with any of them after a thousand miles or so.
And yeah, because of the thickness we had to play with bolts and shuffle them around a bit along with some extras to get the right length ones everywhere, so have to keep that in mind.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 08-15-2011, 09:02 PM
Hendog's Avatar
I just repacked my CVs. I removed the old bolts, which were never removed before (100K Km). I replaced with same size (new) bolts. There were no Schnorr washers originally nor did/do the new bolts extend by any amount out the other side. This has lasted 24 years and 62K miles.
But I won't rest easy now until I replace those bolts with longer ones and install Schnorr or Nordlock washers. In the meantime I'll keep an eye (and torque wrench) on them.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 08-15-2011, 09:31 PM
Hendog, I think CV bolts backing out is an 8mm bolt issue. The 10mm bolts torqued to 60 ft*lb (which an 87 should have) probably takes care of the issue - that's twice the clamp load of the 30 ft*lb (or therabouts) 8mm bolts, which is a lot of headroom.
Old 08-16-2011, 02:26 AM
Tut Tut is offline
Chris,
I have Schnoor washers by the piece. What size are your bolts?
Tut
'87 Carrera coupe
'08 BMW 535 xiT
Old 08-16-2011, 06:25 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by Hendog View Post
... But I won't rest easy now until I replace those bolts with longer ones and install Schnorr or Nordlock washers. In the meantime I'll keep an eye (and torque wrench) on them.
Henry
Did you had any washers? When I drop the engine (86 from a 83SC) there was no washer and no plate either (PP indicate its use for the 10mm bolts).
The bolts are M8 by 50mm (60mm with the head), so now I've got no smuck what suppose to be there...
Who Will Live... Will See
Old 08-16-2011, 03:10 PM
Hendog's Avatar
Originally Posted by JJ 911SC View Post
Henry
There were no Schnoor washers but there were/are the half moon washers which span two bolts. The bolts on my car are M10x50mm.
Henri
Old 08-16-2011, 03:30 PM
Porsche Crest
I got mine at Fastenal.
Old 08-16-2011, 07:05 PM
Here's the "Stage 8" solution I bought after finding in a post on the forum. They are a great idea and should prevent unwanted "incidents" I especially like the 12pt socket heads instead of allen head bolts!
Ideola's Garage: Stage8 Fasteners for Porsches
Found that link in the old post below. Seems there was some sort of "group buy" going on, but I think you can still buy them from the link above. Read this post for more info.
Stage8 Locking CV Bolts for ALL 911/912
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-16-2011, 09:02 PM
