SMHemmah
hemmah's Avatar
Shifter spring install
OK I did it. I removed the 2 springs in my shifter and I can't get them back in. See photo.
Any suggestions on how to get the springs back in?
Or can I not put the springs in and just bolt the plate back in?
1969 911T
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 08-01-2013, 03:46 PM
SMHemmah
hemmah's Avatar
How to put shift springs back in
Folks I figured out how to get the springs back in the shift. I had to cut the springs down by 1/3 put then in with a bolts and lock-nuts. Lesson: don't take the springs out of the shift
See the photos:
Start with bolts, lock nuts, lock washers, springs and shift:
Add bolts, lock nuts, lock washers, cut sprints down by 1/3 and shift
Tighten nuts on springs and lock nuts on shift body. Tighten springs to good tension
Top view
Old 08-03-2013, 04:45 PM
Discseven's Avatar
Aloha Hemmah,
I've been thinking about diving into my shifter... your post has pushed me over the edge! So I have to ask... why did you dig into this? What's to replace in that area?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-03-2013, 07:03 PM
SMHemmah
hemmah's Avatar
Aloha Discseven,
My adventure into the shifter was a mistake. I bought a replacement bushing pack and started taking stuff apart.
I got it all together again with new bushings. Works good.
Don't take the springs out of your shifter.
Old 08-03-2013, 07:24 PM
Walt Fricke's Avatar
Sounds like a commercial: don't take the springs out of your shifter, or you'll end up in a roadside ditch (or selling your hair for wigs)!
Shortening a spring makes the spring stiffer. Guys who lowered their cars by cutting a coil found that piece of engineering fact out the hard way.
So have you noticed that you have to push harder when shifting to get to where you want to go? That's not necessarily a bad thing. You used to be able to, and may still be able to, buy stiffer springs for this application. Came, as I recall, with a warning that they were tough to install. But you cut quite a lot off, so it should be quite a bit stiffer.
And can we assume that you can get to all of the shift planes? You don't run into coil bind when going for the side where the springs are most compressed?
Old 08-03-2013, 08:49 PM
SMHemmah
hemmah's Avatar
Walt,
Yep the shift spring experience has been a bad commercial.
I did think about the spring stiffness and binding when I engineered the solution. The stiffness is set by how much I tighten down the inside bolts. So it is adjustable as the original was not but optimal to Porsche Engineering. I tightened until the springs just started to bend - similar to what was original. So no binding.
Bottom line the shift springs work as they did before - feels the same spring wise. The bushing are replaced. The commercial is a happy one now.
Take care,
Old 08-07-2013, 08:29 AM
Discseven's Avatar
Thanks for the reply Steve! Got it on the "Don't take the springs out!"
... does sound like a commercial!
Karl ~~~
Old 08-07-2013, 08:39 AM
tobluforu's Avatar
I remember doing this 20 years ago, got damn springs shooting accross the living room, swearing, etc..
Old 08-07-2013, 08:44 AM
SMHemmah
hemmah's Avatar
Yes the springs shot across the room. Swearing was involved. Even more swearing trying to put them back in.
Old 08-07-2013, 04:47 PM
I just rebuilt my shifter last week. The first spring removed...I caught with my chest...;-)...the second removed we placed a rag over it.
Placed in a vise, cleaned all the parts and inserted one end of the spring against the plate, driver's side (over the end of the pin pushed through about a 1/4") and "bowed" the spring upward in the middle and then pushed/worked the other end in place.
I would rate it as a one beer job.
Glenn
Old 08-07-2013, 06:18 PM
Classic's Avatar
And old screw driver with an appropriate slot cut into it does the trick for the re install, about 5 minutes.
Classic 1969 911T
Old 08-07-2013, 08:52 PM
