Onnfire's Avatar
Did i blow the engine
I just put in a new fuel filter in my 3.0 liter today because the car was stalling after about 3 or 4 minutes idling. It seemed to fix the problem then I took the car for a ride and it felt like I had a seized caliper on the front driver side brake, next thing i know is there is a hell of a cloud of white smoke in my rear view mirror so I imediately pull over and turn it off. Temperature guage was about 190-195. When I try to start it all it does is turn over but blows smoke out the bottom of the engine. What do you guy's think??????
Old 08-19-2011, 10:28 AM
Wer bremst verliert
JohnJL's Avatar
Take a picture of where that smoke is coming from.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-19-2011, 10:48 AM
Make Bruins Great Again
Por_sha911's Avatar
The smoke and feeling like a seized caliper should have nothing to do with the filter. Did you knock loose a wire or crack a old and brittle hose? Anything leaking? What year car?
Joe
Old 08-19-2011, 10:51 AM
Onnfire's Avatar
I did forget to mention that I did turn the adjustment screw on the carb which seems to have brought up the idle a little bit, my neighbour seems to think that it is the fuel air mixture screw. I did get the car running and brought it home where it is smoking a little from the drivers side exhaust and after 10 minutes idleing it is still smoking. I turned that screw back to it's original position. The car is a 1977 and i believe the engine is a 1978 3.0 liter
Old 08-19-2011, 11:19 AM
kodioneill's Avatar
Did you change the oil before this happened?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-19-2011, 11:32 AM
AutoBahned
RWebb's Avatar
year of your car?
not stock if a 3L with carbs so describe it completely
did you turn the motor over by hand?
how long since it was modified?
Old 08-19-2011, 12:25 PM
Onnfire's Avatar
No I was just about to take it to a friend to change the oil, just received the oil filter and bought the oil today. I am pretty sure it was the air fuel mixture screw I was playing with that caused this. Now I get smoke out of the drivers side exhaust pipe and if the car stalls I have a hard time getting it to start so I obviously have the fuel/air mixture set wrong
Old 08-19-2011, 12:30 PM
Onnfire's Avatar
year of your car?
Motor is not modded, just chain tensioners and headers to a WICKED EXHAUST system. Cis fuel system
Old 08-19-2011, 12:32 PM
No carb(s) on a 3.0L. They were all CIS, stock.
Are you trying to say that you fiddled with the mixture screw on the CIS? ...and it ran fine before that?
Old 08-19-2011, 01:52 PM
tazzieman's Avatar
Please give an exact timeline of the problem.
Did it (stalling at idle problem) start suddenly , was it purchased in that state , or after you(or someone else) had done something else to the engine? Have you done other tune up items?
Did you alter the CIS mixture screw before you changed the filter?
Are there any vacuum leaks?
I'm sure the engine is fine...just needs a mechanic au fait with CIS to take a look and analyse the mixture. A logical approach will solve almost any issue.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 08-19-2011, 04:11 PM
Onnfire's Avatar
Yes I did fiddle with the mixture screw after I changed the fuel filter. (SHOOT ME NOW) I changed the fuel filter because it would only idle for about 3-4 minutes then it was gasping until it stalled. If I was driving the car and was coming to a stop it would die. Now I have it idling good but I have smoke out of the drivers side exhaust only. I used to get water droplets before for a few seconds and now it is spitting out gas, Drivers Side Only
Old 08-19-2011, 06:03 PM
RETIRED
Joe Bob's Avatar
Did i blow the engine?
I dunno, did ya burn yer lips on the exhaust?
Best to get an exhaust analyzer and get the mix right.....
Old 08-19-2011, 06:30 PM
El Duderino
tirwin's Avatar
Joe Bob,
This one's for you!
CHIMP ON PENGUINS - YouTube
Old 08-19-2011, 07:43 PM
