ttweed's Avatar
Originally Posted by la2mtl View Post
This is a rough prototype of the handle. I plan on reworking it a bit to be more ergo-friendly, but when finished it'll get it's own leather sleeve...
I did a similar treatment on my R-look '68, fabbing my own panels and covering with vinyl (no hi-dollar leather here, unfortunately), pull straps for the lexan windows, and making the door handle out of a piece of 3/16" x 1" aluminum bar stock. I just polished the handle to a "brushed" finish and didn't bother covering it with a fabric sleeve.
Good luck with your build. It took me 5 years for mine, but it's fun as heck now that it's done.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 10-13-2012, 07:18 AM
la2mtl's Avatar
Progress update:
Found a great welder who has been kind enough to take on the replacement sheet metal. It's coming along nicely! Fuel pan is in, rear shelf is in, radio and ash tray deletes are in! Pics to come!
Old 01-09-2013, 02:25 PM
What material did you use for the brown leather straps?
Old 02-20-2013, 08:56 AM
la2mtl's Avatar
If you're referring to the leather for my project, the leather comes from old cut up leather belts. I'll be using vintage tan hide for character; door stops, pull straps, etc...
1967 SWB (Under Construction)
1992 Range Rover County
Old 02-20-2013, 03:06 PM
la2mtl's Avatar
Dash in leather. New fascia metal and perforated insert. Paint is satin black. Gauges haven't been addressed yet, but you know they're going to NoHo.
Old 04-27-2013, 04:44 PM
Bird. It's the word...
Fishcop's Avatar
Great work.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 04-28-2013, 05:54 PM
la2mtl's Avatar
Thanks man.
Old 04-29-2013, 02:47 PM
la2mtl's Avatar
Interior
German square-weave under a bit of chrome...
Old 05-04-2013, 11:48 AM
Uncertifiable!!!
Uwon's Avatar
Just came across your interesting thread. Nice work. I need to do the same. Can you expand on how you covered the dash- what crack filler and glue did you use? Did you use one piece leather or did you make a cut line at the transition? Who supplied the leather?
Where did you get the square weave carpet?
Cheers.....
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 05-09-2013, 03:51 AM
la2mtl's Avatar
Thanks.
After removing the dash and stripping the cracked vinyl, I cleaned the metal, spray with a rust inhibitor, and then laid one large leather directly over. Fitting it was a tedious. I started in the middle and worked outwards; used a green contact glue just under the lip along the perimeter. I used a bit more around the contours and it fit/adhered to a smooth finish. I cut an oversized outline of the dash, but that made me a bit nervous as I came close to running out of room as I approached the passenger side...
The fascia/dash had the usual ash try and later-model radio cut outs in the metal. I spot welded the openings closed completely. The look originally was to leave the fascia uncovered and just have a smooth metal finish. I found a complete four-piece metal trim set on eB*y in mint condition so I couldn't pass it up... the perforated leather was bought through Pelican.
I used the same glue on between the perforated leather and the metal trim. That wasn't too difficult. I started from the center and worked my way outwards.
I plan on making a mahogany insert to swap with the perforated leather eventually. I like the idea of having different sets to compliment different looks. Either way I do plan on adding a pair of track watches mounted where the radio used to be on a polished metal plate.
So many directions, yet so little time and soon money!
-Steve
Old 05-10-2013, 03:40 AM
