ivangene's Avatar
Wheel Fitment (offset) Q:
sorry, I am just no good with offsets....I am selling a set of wheels:
fronts 7" 55ET 993.362.114.00
rears 9" 70ET 993.362.118.01
and someone asked if they would fit an 89' C4 without spacers or fit up issues?
can anyone offer an answer
(BTW I dont think I have ever seen a C4 from 89' - didnt know they made them)
TIA - I thought you might like a picture for your efforts
Ed
Ed M
86' Coupe
Old 08-24-2011, 06:45 AM
Bill Verburg's Avatar
Ed
the fronts will fit ok, 7 ET55 is an oem fitment, but the rears will need spacers. 964 n/b rear 9 should be ~ET55
Bill Verburg
Old 08-24-2011, 08:01 AM
ivangene's Avatar
so if I read it right it should need 15mm spacers (not much...) are the studs long enough or would you need longer ones (and are the studs in the hub or the bolts to hold on the wheel...
Thanks Bill
Ed M
86' Coupe
Old 08-24-2011, 08:52 AM
Thanks Bill
Either new studs or a spacer w/ studs
Bill Verburg
Old 08-24-2011, 08:58 AM
racer's Avatar
Porsche introduced the 964 as a C4 in 1989, Coupe's only version. Overlapping the last year of the "older" car which was available as coupe, targa, cab
Something like this would work for the rears: H&R TRAK+® Wheel Spacers | Products || H&R Special Springs, LP
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-24-2011, 09:09 AM
ivangene's Avatar
thnaks guys... I googled it and see it is a 964 (which I didnt think of till you said so)
this "potential" buyer isnt very mechanical sounding and so if it isnt "bolt on" he's most likely out, but thanks for the info and I read more posts from Bill regarding fitment...all good stuff
CHEERS!
Ed M
86' Coupe
Old 08-24-2011, 09:23 AM
Max Sluiter
Flieger's Avatar
That car still has the US high-nose ride height. Probably scary driving on the freeway like that.
Old 08-24-2011, 11:59 AM
ivangene's Avatar
yea pretty ugly ride height....
Ed M
86' Coupe
Old 08-24-2011, 12:07 PM
ivangene's Avatar
sorry but I have a really thick noodle -
having never run those bolt on spacers, do the spacers get bolted to the stock studs and then the wheels use the studs on the spacers (I Know the answer is yes) but if the spacer is thin wont the stock studs protrude into the wheel? - how does that work....anyone have a picture - seems like you would have 10 studs sticking out / wheel
my "buyer" is coming several 100 miles and we want to be absolutely sure before committing to the trek
TIA!
Ed M
86' Coupe
Old 08-26-2011, 06:21 AM
Max Sluiter
Flieger's Avatar
The proper way to do spacers is to have longer studs pressed into the hub and then put the spacer on (one with just holes) and then the lug nuts, making sure to get full thread engagement, or use open ended lug nuts.
Old 08-26-2011, 11:14 AM
ivangene's Avatar
I totally agree and if it were my car that would be the only solution....
however that is not what this guy wants to do dispite my advice so i am looking for the "other answer"
Thanks for your comment
Ed M
86' Coupe
Old 08-26-2011, 11:54 AM
Max Sluiter
Flieger's Avatar
I think it depends on the wheel. Fuchs have reliefs between the 5 places where the bolts go, right?
Old 08-26-2011, 06:41 PM
