spark plug problems 80 sc
This afternoon I changed the driver side spark plugs. It was way overdue. After hooking everything back up, started it to see if she ran ok. Started fine but did not sound right. Took her for a spin and she ran like garbage. No spunk when pushing on the accelerator. Idles ok. Pulled each of the plug wires off, one a time and when I pulled I could tell that cylinder was getting no fire, replace wire and pulled next. Same symptoms. Any suggestions?
Old 01-05-2012, 12:38 PM
Peter Zimmermann's Avatar
What make, heat range and plug gap did you use?
Keep the Shiny Side UP!
Pete Z.
Old 01-05-2012, 12:47 PM
Just some guy
Sounds like maybe you have a failed plug wire. Swap with another one if possible, see if the failure follows the wire. If not, I'd suspect a bad plug. Swap the plug around, see if the failure follows the plug.
Six cylinders for whatever reason seem to idle fine and drive passably on 5 plugs. It's only under load that you really notice it.
Don't drive it like this - unburned fuel will overheat the cat. Ask me how I know that one. Here's a hint, it ended with a phone call, "honey, I need you to bring me a fire extinguisher RIGHT NOW."
Old 01-05-2012, 12:56 PM
spark plug problems
The parts store did not have the same plug as original but matched it to a champion plug with the same "specs". I always do one side then run it to make sure everything is ok before going on. Glad I did now. Could a vac hose come off somewhere ? The warm up regulator has a hose nipple showing with nothing attached. Could I have dislodged a hose? Thanks
Old 01-05-2012, 12:58 PM
plug gap was .76 mm as per
manual.
Old 01-05-2012, 12:59 PM
I know you will think that this is crazy, but make sure that you have actually connected your plug wires to the plugs. It is easy to get the rubber boot of your wire caught between the cylinder and the plug and you think it is connected.
Old 01-05-2012, 01:29 PM
Flat Six
Flat Six's Avatar
"changed the driver side spark plugs" -- not pass. side too? mixed plug types
"Pulled each of the plug wires off, one a time and when I pulled I could tell that cylinder was getting no fire" -- likely not wires or (mis)installation
"matched it to a champion plug " -- ugh. Still, post the plug # to verify cross-reference was correct
"The warm up regulator has a hose nipple showing with nothing attached. Could I have dislodged a hose?" -- yup, likely vacuum leak
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 01-05-2012, 01:45 PM
IMO, Champion plugs belong only in lawnmowers and flat head Fords...
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 01-05-2012, 01:51 PM
T77911S's Avatar
.76 is a bit wide.
they did not have NGK or bosch?
only use copper plugs, no platinum or anything fancy.
i have never heard of anyone changing 3 plugs then driving it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-06-2012, 07:15 AM
Flat Six
Flat Six's Avatar
Originally Posted by T77911S View Post
.76 is a bit wide.
.76mm = ~ .030"
Dale
Old 01-06-2012, 07:30 AM
