Help! 1978 911sc Door lock driver side would NOT open from inside round knob
I need advice how to fix driver door lock for my 1978 911sc...
The door lock would not open from inside round rotation door knob but would open with inside pull-up lever handle...
The key would not work either from outside...
Any advice highly appreciated...
Old 08-30-2011, 10:28 AM
plumb4u2's Avatar
I would recommend pulling door card to inspect linkages.
when I bought my car the little pull up knob was missing, When I removed the card I found it down inside disconnected, put everything back together and all is well
I assume that your linkage from the round knob has come apart...this job is very easy to do only about 6 or so screws to remove door card and all the linkages are pretty straight forward
p.s. there is a plastic membrane that should be fixed to the door behind card I you remove it it should be put back, this is a vapor barrier
Justin
84 Carrera Targa
98 F-150 4x4
Old 08-30-2011, 12:40 PM
My round door knob linkage - just fine...
I may suspect the malfunction of the locker itself...!?
as if I turn/swing the side door assembly latch - round knob would function but as soon as I release outside lock lever handle - inside round knob would not work...
The key would not work either...!?
Old 08-30-2011, 01:19 PM
