Electrical guru's--Need help-Window Relay
My windows and sunroof stopped working...traced it down to the relay. I pulled the relay and took it apart. I can put a spacer between a contact(picture 1 and 2), causing another contact to make contact and the windows will work. My belief is that there is a capacitor(picture 4) that has gone bad becaue it gets very warm when the relay is energied....reardless of the spacer...but I am really out of my element. Pic 3 is the schematic.
1986 3.2 Carrera |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Indeed, capacitors are the "usual" suspects in a failed circuit such as this one. Although, the relay may have dirty contacts, or is not closing due to a cold solder joint. pm me as needed. Gerry ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 09-05-2011 at 07:06 PM.. |
Platinum Member
Relays are simple to test... put 12 volts across the windings, and it should close. Measure resistance across closed contact, it should be nearly 0.
Manassas, VA
The role of the capacitor, C1, in this circuit is to quickly charge, in about 1/2 second, when the ignition is turned on. The charged capacitor keeps the relay de-energized. After the capacitor charges, no current flows through it from pin 85 to pin 86 until the door switches are closed which provides a path for the capacitor to discharge and the relay will latch to power the window motors.
The diode, D2, prevents a reverse voltage spike, the inductive kick, when the coil de-energizes and allows the voltage to flow back to ground. The combination of R1 and D4 act as a snubber circuit to prevent arcing across the relay contacts. dad911, in the post above, describes a relay test but this will not test the function of the shunt capacitor, C1, or the snubber circuits. Reflow the solder joints on the back of the circuit board and you may solve the problem. Mark
1991 964 Polar Silver Metallic Turbo Coupe Last edited by lucittm; 09-05-2011 at 06:11 PM.. |
Friend of Warren
Where is that relay located? I was trying to trouble shoot this a couple of weeks ago and couldn't find it on my '86.
Kurt V No more Porsches, but a revolving number of motorcycles. |
It is behind the oil temp / pressure gauge.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
"The role of the capacitor, C1, in this circuit is to quickly charge, in about 1/2 second, when the ignition is turned on."
Since the diagram is totally wrong, the above analysis is also totally wrong, First, the circuit is a delay timer run off the 'X' pin of the ignition switch to power the windows after the ignition switch is turned off. Pin 85 goes to the 'X' terminal of the ignition switch. Second, this relay has a transistor not shown on the posted erroneous wiring diagram (but on the opened relay picture), which most likely comprises the delay function with the capacitor. Bottom line: Before analyzing what could be the problem with the relay, let's try and post the correct diagram!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 09-05-2011 at 09:51 PM.. |
