moparrob's Avatar
Is this the correct way to install the engine harness?
Hi Guys,
I'm putting my engine (1979 3.0) back together and am in the process of installing the alternator harness and shroud. I couldn't find any good diagrams of how the bundle should lay in relation to the shroud fins and the ground strap so I tried to use common sense.
here are some pics:
and the other side:
Does this look correct? If not, any suggestions on a better method?
Rob
Old 09-03-2011, 09:24 PM
Almost Banned Once
sc_rufctr's Avatar
They look fine as they are although I'm not sure how you could stuff this up.
- Peter
Old 09-03-2011, 10:15 PM
moparrob's Avatar
With the luck I've been having lately I figured better to ask now than to find out after I have attached the shroud and carbs that it all needs to come apart later.
Thanks.
Old 09-03-2011, 10:33 PM
1988 Carrera
shadowjack1's Avatar
I just put mine back in and it looks the same as you have it set up. I see no problems at all.
Old 09-04-2011, 05:05 AM
Targa Time's Avatar
The only issue I can see is if you need to replace your alternator in the future you may not have enough slack in the ground strap. Usually the strap is long enough that with the alternator in position it doubles back on itself.
Old 09-04-2011, 05:28 AM
