Engine smokes at idle
I purchased sw chip and very pleased with the performance however I did notice the engine exhaust smoked a little bit after the chip replacement. Now when I turn on the air-conditioner she will smoke you out of the garage especially after charging the system. What are your thoughts. Could the additional load of the compressor cause excessive smoke at idle? Its seems to be oil burning...not black smoke that I can tell or its time for a top end job?
1986 Porsche Carrera ![]() 1997 Porsche Boxster (Sold) :0 1995 911 Cabriolet (Sold) ![]() 1971 Porsche Targa 911E (Sold)
Mo money = mo parts
"Could the additional load of the compressor cause excessive smoke at idle?"
No. "Its seems to be oil burning...not black smoke that I can tell or its time for a top end job? Sounds suspicious. Is it using oil? Meaning...how many miles can you drive before you need to add a quart of oil?
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
abit off center
Did you remove the cat?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Yes, I removed the cat and noticed an awful smell soon after...my friends would comment about the smell when following me. The engine doesn't smoke under acceleration ,just at idle...valve guides I suspect.
abit off center
The cat was masking the oil burn smoke, mine did the same thing, come to a stop and she would belch smoke... it was not the chip but removing the cat that let the smoke show its self. Most likely valve guides.
I'm thinking the same thing...I'm looking into replacing the cams with the 964...Is there a noticeable change in idle and performance? I might as well change it since I'm in the engine.
