redstormcoach's Avatar
Can't get heat to stop coming into car
I have a 1982 911SC and I have constant heat coming from the passenger side vent. The tiny one by the window. The defroster levers are down. I check the heater boxes and made sure the vent holes were open; meaning the flap inside is closed.
I removed the hose that comes up to that vent and found that the hose that comes from the floor on the right side of the passenger foot well is blasting out heat. I have no problem with the drivers side.
Thanks for any help. Its not fun driving in 80 degree heat with the heat on
Old 09-12-2011, 03:37 PM
schumicat's Avatar
the flapper box isn't closing right. it is a little box which has a round sliding cover (like a Kraft grated parmagean cheese dispenser) that is not closing all the way. you need to get under the car and adjust the pass. side one so it so it is fully closed when the heater lever is down.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-12-2011, 03:51 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by redstormcoach View Post
... Its not fun driving in 80 degree heat with the heat on
A few more weeks and you'll be glad you have the heat
Did you take the hose of to physically check the inside of the flapper box to confirm the flap is actually closed? You should check both to them to compare.
If the red plastic bushing (NLA) is broken, the inside flap may not be fully close.
Who Will Live... Will See
Old 09-12-2011, 03:55 PM
JJ 911SC's Avatar
schumicat
I'm a 2 fingers typer going ove the post 2, 3 time... so I just saw your post.
I agree it's not closing properly. So it should have been a +1
redstormcoach
Your are luky, since its a mirror system, you can easily compare between the 2 sides.
Good Luck and keep us posted
Old 09-12-2011, 04:03 PM
I had the same exact problem on my 1982SC. The spring on the flapper box had disconnected on one end and was hanging by the other. I bent the unhooked spring end a little more with two pliers and reattached it to the flapper box arm. Now I only have heat when needed.
Old 09-12-2011, 04:40 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Heat.
One of the butterflies is not opening completely.
pm me as needed.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-12-2011, 05:20 PM
Butterfly
Here's a pic of a partially open butterfly.
Partially open. (some heat).
And fully closed-Broken cable-(heat).
1986 911 Targa.
Only in L.A.:
Old 09-12-2011, 05:26 PM
JJ 911SC's Avatar
and here is the inside view;
Originally Posted by JJ 911SC View Post
After posting some photos of cleaning the Flapper Boxes that I got from Peter Seow ($40 delivered from Singapore), Felipe asks me about the cleaning process, so here it is.
I disassemble one at the time so I could have a reference when it came time to reassemble (mirror image to each other);
My basic cleaner is call Facto AT-30 from http:www.swishclean.com/clean-itcenters.htm?ECINFO=//SWISHLOCATIONS (Canada/US/Europe)
Less than $5 a Liter when bought in a pale. Hopefully there is a store close to you.
Check my cleaning thread: http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html
Step 1: Remove the spring on the other side (not shown) and clean the center piece.
Step 2: Remove the captive clip from the shaft.
Step 3: Carefully removed the plastic bushing (red) by prying it side to side. It may already be cracked or you may crack it or split it all together. I don’t think you can buy them on their own but even if they are cracked or broken (crazy glue should work) they should still work as the fit into a recess.
Step 4: Pull (or pry off) other side as the shaft slide through the flapper. I may require a gentle hammer hit to get it loose.
Step 5: Removed the inside flapper.
Step 6: Clean/paint to you heart content.
Step 7: Reassemble by sliding the bar through the flapper (the cleanest side go toward the inside of the car as shown).
Step 8: Insert the plastic bushing.
Step 9: Secure the retaining clip on the shaft end.
Step 10: Reinstall the spring.
Old 09-12-2011, 05:32 PM
muck-raker
kidrock's Avatar
very nice write-up, JJ....good job.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-12-2011, 06:05 PM
theclaw's Avatar
Nice work. Going to have to do this myself too.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 09-12-2011, 06:50 PM
