GOM (Grumpy Old Man)
Busta Rib's Avatar
Advice needed: SC electrical problems
Just recently, the following components have been cutting in and out intermittently in my 1980 SC. They will occasionally all go out and come back at the same time:
stereo
cigarette lighter
fog lights
rear defroster
sunroof
speedo
I checked the fuses, all OK. I checked the ground for the stereo and it is solid, as well as the hot wire going into the stereo, which comes in directly from the battery, which is perplexing to me. Are all of these components on one circuit typically? Or am I dealing with an aftermarket wiring job from a previous owner? I am not a keen electrical person, purely a novice. I have a friend that is more knowledgeable that will help me troubleshoot, but I was just curious if there are some tips/insight anyone can share of this possibly being a common problem/solution with these particular items. Thanks in advance.
Jim
Instagram: @3pedalposse
Old 09-12-2011, 01:55 PM
Alter Ego Racing
ErVikingo's Avatar
Check the ground strap on the transmission.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 09-12-2011, 02:05 PM
Gary H 1978 911 SC
Just because the fuses are not blown, they may be the issue. Take out each fuse and scotch brite each fuse and fuse holder, One at a time and give them a spin after you re install them to make sure they are seated. Those fuses will have a little corrosion on some of them.
Old 09-12-2011, 02:19 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
stereo
cigarette lighter
fog lights
rear defroster
sunroof
speedo
Jim
Jim,
Do you have voltage on both sides of the fuses?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-12-2011, 03:34 PM
Busta Rib's Avatar
Originally Posted by 86 911 Targa View Post
Jim,
I'll check the voltage and the ground strap tomorrow and get back to you guys. Thanks.
Old 09-12-2011, 03:42 PM
