Paint code color questions?? help! Slate Grey
Need an equivalent code for slate grey that will enable a dupont match. Any ideas??? Already found polo red if anybody needs it. Thanks
Old 07-19-2001, 04:05 PM
Post
Paternie, in the Red Book, lists Slate Gray metallic as a special order color, code 22D. Looks like it was first available in 1989.
Rod Walter
'88 911 coupe
Old 07-19-2001, 09:48 PM
Post
I have it first listedin 1965, and a small swatch from a color book in 6.1965.
Need someone that has a du pont number, thanks though
Old 07-20-2001, 06:52 AM
Post
You're right. I started looking with model year '73 and didn't find anything until '89. There is an earlier version of slate gray with Porsche code 6801. Couldn't a body or paint shop use this number to find the paint composition and mix it using DuPont paint?
Rod Walter
'88 911 coupe
Old 07-20-2001, 05:43 PM
Post
Hmmm. That's interesting. I've got slate gray metallic on my 1978 930. Was told it was a specialorder from the factory.
Don't know the duPont number, though.
Old 07-20-2001, 08:15 PM
