key/lock codes
I have an ignition/barrel/lock unit from an SC, but no key.
I thought the key code may be imprinted on the body somewhere. There are some numbers, but mainly look like part numbers. is there anyway of finding the key code to cut a new key? Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I beleive that if you go to the dealership, they can look it up via the VIN number. I just took my to my Porsche mechanic and he had one made for me as my regular key was about to shear off. YMMV
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
I'll - give it a go. I have a number - not sure if it is the VIN number or not . There is a number stamped in the dash panel, which may be a VIN number. It is out of a wrecked car - body gone.
Alan,
The number stamped in the dash panel is the 'production number' not the VIN. I think your importer can have Porsche AG tie that number back to the VIN and your key-code. Give it a try. Also, I would think that the salvage operator would be required to maintain a record of the VIN. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
From what I understand now in order to get a stipulated lock cylinder or stipulated key you have to show proof of ownership of the car---title and registration shown to dealer.
Hmm thanks Grady. I was the salvage operator - or 2nd in line. I inherited a partly dismantled body - but never recorded the chassis number.
Might be a lost cause. Thanks Alan
Well I took one of my other P keys in to the corner locksmith to get a duplicate cut. Showed him the barrel unit, he reckons he can cut one without any of the above info.
We shall see. keep you posted. Alan
OK, took a while - but I did tell him was not urgent. He cut a key from the lock from scratch, with nothing but the lock to work with. What I failed to do was ask for a price. $120. However, looking at the parts list it would cost near $700 for a new unit. So I probably am winning if I need a new ignition barrel sometime.
But it can be done without any numbers. Obviously the key code would shorten the job. Alan
