<insert witty title here>
Christien's Avatar
I know what you're saying - waiting for stuff to come in the mail is a pain. Count your blessing you're at least in the same country as Pelican... I'm very much of the belief in the right tool for the job, but understand that's not always an option.
In a pinch, I think the metal bar in the holes would be ok once or twice, but a screwdriver won't be strong enough - it'll just snap.
But you found the right tool anyway, so that's good.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-21-2011, 05:15 AM
as some have said...leverage is your friend. first time I tried this just using tool nearly tore my hand off. Added a couple of pieces of two foot pipe to the process and finally broke free. You want to make sure and not rotate the engine the wrong direction, just FYI...can cause bad things to happen.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-21-2011, 05:30 AM
Originally Posted by 86 911 Targa View Post
Somebody posted this a while back.
As for the nut, you may need a ratchet/socket,
and some type of torque amplifier on your ratchet handle.
A long pipe?
Good luck,
Gerry
that was my post. set the handle of the proper spanner on top of the motor mount tab, like in the picture. then all you have to do is use a socket and ratchet on the but.
206 637 4071
Old 09-21-2011, 09:01 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I have this off. A friend lent me the proper tools. Now that I have reinstalled the belt it is too tight. I am currently troubleshooting that.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-21-2011, 09:19 AM
Christien's Avatar
Search here on shims - you should have 6, and you move them around (inside or outside the pulley hub) to adjust tension on the belt.
Old 09-21-2011, 12:11 PM
2 shims inside and a continental belt usually works. 6 total.
206 637 4071
Old 09-21-2011, 12:23 PM
rs6er's Avatar
I have a 10mm on. Fits with 4 in, 2 out. At least it does today. Make sense?
John
Old 09-21-2011, 02:13 PM
9.5mm usually takes two. 10mm, maybe 4, so check it again after running for a day or two.
206 637 4071
Old 09-21-2011, 02:50 PM
Ummmm... So what worked for you, besides the proper tools? Did you just need the pulley wrench alone, or did you need to use a cheater pipe on the pulley wrench? Or, did you use the wrench against the motor mount shown in the posted pic?
Brett
Old 09-21-2011, 03:15 PM
rs6er's Avatar
I used PB Blaster a few times over about 15 hours. I got a proper spanner wrench (Pelican variety) and a 24mm 1/2" socket. No cheaters necessary.
It was very useful to position the spanner so it pressed against the engine mount.
John
Old 09-21-2011, 04:09 PM
