<insert witty title here>
I know what you're saying - waiting for stuff to come in the mail is a pain. Count your blessing you're at least in the same country as Pelican... I'm very much of the belief in the right tool for the job, but understand that's not always an option.
In a pinch, I think the metal bar in the holes would be ok once or twice, but a screwdriver won't be strong enough - it'll just snap. But you found the right tool anyway, so that's good.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
as some have said...leverage is your friend. first time I tried this just using tool nearly tore my hand off. Added a couple of pieces of two foot pipe to the process and finally broke free. You want to make sure and not rotate the engine the wrong direction, just FYI...can cause bad things to happen.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
that was my post. set the handle of the proper spanner on top of the motor mount tab, like in the picture. then all you have to do is use a socket and ratchet on the but.
I have this off. A friend lent me the proper tools. Now that I have reinstalled the belt it is too tight. I am currently troubleshooting that.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Search here on shims - you should have 6, and you move them around (inside or outside the pulley hub) to adjust tension on the belt.
2 shims inside and a continental belt usually works. 6 total.
I have a 10mm on. Fits with 4 in, 2 out. At least it does today. Make sense?
9.5mm usually takes two. 10mm, maybe 4, so check it again after running for a day or two.
Brett |
I used PB Blaster a few times over about 15 hours. I got a proper spanner wrench (Pelican variety) and a 24mm 1/2" socket. No cheaters necessary.
It was very useful to position the spanner so it pressed against the engine mount.
