I'm not here.
K. Roman's Avatar
How do I remove a broken Lug nut???
I'm trying to remove my front drivers side wheel and one of the lug nuts broke off leaving the base in place inside the fuch, still screwed in very tight. I've sprayed it with Rust Off, and have had no luck removing it. Anyone with a "bright" idea???
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 08-08-2005, 12:41 PM
RETIRED
Joe Bob's Avatar
Some people have luck with a deep hole saw that fits over the shaft of the threaded stud.....spin it up and cut carefully.
2012 ML350 3.0 Turbo Diesel
Old 08-08-2005, 12:44 PM
I'm not here.
K. Roman's Avatar
Thanks,
what size do I use? The lug is a 19.
Old 08-08-2005, 12:49 PM
si Banker's Avatar
Broken lug nut
Buy a hole saw, as deep as possible, but just bug enough to fit over the stud. The hole saw will cut the base of the lug nut and you will be able to remove the wheel and then with the wheel off you could then replace the stud.
In the future you should keep a coating of lube on the studs.
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 08-08-2005, 12:51 PM
RETIRED
Joe Bob's Avatar
Take a pair of calipers....I don't have my book in front of me....and measure the STUD....get a hole saw the size of the stud.....I'm assuming it's broken off all the way down toward the bottom up against the wheel?
Anyways, get a couple of them, and try to cut with the drill on reverse....the heat and the directional torque may break it loose. Hit the stud with PB Blaster or Kroil before....don't use WD-40 that stuff sucks....
Gud luk....
Old 08-08-2005, 12:54 PM
Used Up User
imcarthur's Avatar
Just did one 2 weeks ago. 3/4" deep high quality hole saw. Remove the guide bit & saw carefully.
Lube the studs lightly & use an anti-seize on the bevel part of the lug nut to prevent future problems.
Ian
'87 Carrera Cab
Old 08-08-2005, 12:58 PM
RETIRED
Joe Bob's Avatar
OH BTW.....IF there is any of the hex left....SOMETIMES an SAE 11/16th socket can be beaten on and will have enuff bite to crack it loose.
Old 08-08-2005, 01:03 PM
the remaining thin threaded shell is removed with a pencil sharp punch and hammer. the wheel won't come off until you remove the shell.
206 637 4071
Old 08-08-2005, 01:08 PM
vash's Avatar
i purchased 4 brand new lugnuts and put my locking ones in a box. i didnt need the potential aggrevation.
k roman, when are you planning on doing this? i wanna see....
poof! gone
Old 08-08-2005, 01:40 PM
Used Up User
imcarthur's Avatar
I didn't have any luck moving it with a punch. When I got down to what is pictured above, I took off the rest of the lug nuts & the wheel popped off with that remainder still wedged in the wheel. The threads were drilled off by that time.
And thanks to JW for his long-ago post on how to do it.
Ian
'87 Carrera Cab
Old 08-08-2005, 01:44 PM
I've read about this happening a number of times so I am curious.
Do they typically get stuck and break because someone may have over-torqued the lug nut long ago?
-Steve
'87 Carrera Targa
Old 08-08-2005, 02:30 PM
Used Up User
imcarthur's Avatar
Mine was torqued correctly & only on for 2 months.
Ian
'87 Carrera Cab
Old 08-08-2005, 02:33 PM
I had this happen when they ignored my request to use a torque wrench. The hard part is getting the leftover metal out of the threads. I finally snapped and beat the hell out of it till enough metal was removed and just took the whole hub to Rennsport here in Tulsa and had new lugs installed. Much faster and was not too expensive at all.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 08-10-2005, 04:09 PM
I'm not here.
K. Roman's Avatar
The hole saw worked like a charm. It took about 3 minutes. Popped right off. The bolt will have to be replaced though, I sort of dug into the threads a little.
Thanks for the knowledge..!
Old 08-11-2005, 11:14 AM
RETIRED
Joe Bob's Avatar
Glad it worked out....
Old 08-11-2005, 11:35 AM
Two Tone's Avatar
This site is so great.
I already know how to fix what just happened to me. I can't believe I didn't think of this myself.
BTW: The nuts were new, lubed and installed by me with a torque wrench about 8 months ago. I just broke 1 out of 20 when removing the wheels today.
Cheers!
1977 911S with a 78 SC Engine
Old 01-12-2007, 04:19 PM
douglas bray's Avatar
Just want to thank you guys for your help today. Especially Ian.
Broken Wheel Lock - Rennlist Discussion Forums
Old 09-24-2011, 07:01 PM
