73 911E Turn Signal Problem
I have a 73 911E with a right front turn signal failure. The marker lights all work ok. The left side turn signals work fine front and back. When I use the right turn signal only the rear light flashes. I have replaced the bulb and get the same result. Any suggestions as to where to look next?
Andy |
Sometimes the small brass contact that presses against the center of the bulb gets bent out of the way when you are removing and installing a new bulb. I would take off the lense cover, remove the entire assmebly and detach the rear cover. You can then give a careful inspection and check voltages if you have a meter. Get a meter if you don't have one. I think the US models have a two filament bulb for side marker and indicator, my euro 911 has seperate bulbs, but the fault finding is much the same.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
