curoswiss's Avatar
Is my new MSD bad? No spark at coils.
I just finished installing my MSD with Pertronix and dual MSD High shock Coils as it's now twin plug and I'm getting no spark. All wires are correct and I have verified power to the unit and have a sold ground.
I have tried to spark the coils but get NOTHING. Am I missing something or is my unit bad? I have a spare but wonder if I should try something else 1st...
Any help is appreciated.
"He has all the virtues I dislike and none of the vices I admire."
1971 911e (will never be sold)
1978 911sc Targa (Sold)
1973 911 RSR (Clone)
Old 09-27-2011, 02:40 PM
curoswiss's Avatar
I called MSD and explained my problem. Tech support said that the ignition wire needs to send a minimum of 9 volts to the thin red wire that is also hooked to the Pertronix. Tech said if I get 0 then I should wire directly to the ignition key.
I just checked and the ignition wire I'm hooking to in the engine bay is getting 11.86 v
Old 09-27-2011, 03:13 PM
Wer bremst verliert
JohnJL's Avatar
Can you post a wiring diagram of exactly what you have installed?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-27-2011, 06:17 PM
curoswiss's Avatar
This is it.
Old 09-27-2011, 07:44 PM
Wer bremst verliert
JohnJL's Avatar
You might trying to simply the wiring first...leave the adapter and one set of boxes out. You say you have twin coils and plugs but the diagram above only shows one set.
I have twin-plugged with MSD and didnt need the adapter or the pertronix so I cant help with those.
Old 09-29-2011, 05:43 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Here is some reading. Not sure it will solve your problem.
Porsche Twin Distributor/Twin Plug Engine - MSD Ignition Tech Support Forums
Old 09-29-2011, 05:50 PM
curoswiss's Avatar
@ JohnJL yes I'm running the coils in parallel as recommended by MSD. I am able to get spark at the coil by disconnecting the white wire and grounding it. Still no spark at the plugs however.
Could the problem be with the Pertronix
Old 10-02-2011, 03:42 PM
curoswiss's Avatar
I called Pertronix tech support and was given the following instructions to test the unit.
Hopefully I'll be able to check this in the afternoon.
Old 10-03-2011, 10:27 AM
Chain fence eating turbo
I'm no help but have installed three 6AL's on different cars and never did they work the first time.
Seems the diagrams are not accurate.
Old 10-03-2011, 11:06 AM
vash's Avatar
just so you know. that MSD display you see on the counter of every hotrod shop? it is also a test unit. you can bring in your MSD and plug it in to the display to test if your's is working.
my shop had to fab up a few quick wires with alligator clips, but it takes seconds to test. i've messed up a few units. i have a friend that works for MSD. he got it fixed for me, and now i have an extra. he sent me one brand new unit to use, and he said to keep it once i got my old one repaired.
i had bought one, but returned it. two spares would be hoarding.
poof! gone
Old 10-03-2011, 12:21 PM
curoswiss's Avatar
Well as it turns out the MSD I bought on eBay is a fake... F*^&#*#(#)
I bought a unit from my local parts store reinstalled and the car started to fire.
It also turns out that my Timing Light is broken so that will need to wait until tomorrow.
Old 10-03-2011, 03:31 PM
