where is this relay?
Thanks for looking.
So I noticed that the windshield washer pump on the front is not getting power. Hence causing this weird issue of leaky cap problem The pump works if I hot wire it. Hence i am suspecting the relay (additional cleanning fluid pump relay) Anyone knows where it is? or has a part #? ![]() Thanks,
Mauricio 87 Carrera Targa |
Found it !!
The switch was fine. The relay part #928 618 113 01 The relay did not test well. It is located behind the RPM gauge
83 911 Production Cab #10
Bravo Zulu (Well Done).
When in doubt, always check the Windshield Washer Pump Relay Locker, Port Side Aft ![]() Old Navy Joke
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
