mray2686's Avatar
Sporatic No Start...with video! so Frustrating
Newbie to the 911 world. Have an '84 targa that has a sportic no start.
In my non-technical words, it sometimes just doesn't turn over!
Battery has been tested. No problems there. DME relay has been replaced.
What's strange is that almost all the time it turns right over and fires up. then times, like today, it won't. i bet it will tomorrow...
I have a Bentley manual and 101 book, so with the right guideance i should be OK finding my way around this thing.
Let me know your thoughts.
'84 targa - no start - YouTube
- 1986 Porsche 911
- 2016 958.2 Cayenne S
Old 08-21-2011, 08:25 AM
Chain fence eating turbo
I'm a little confused. When it wont start, you are saying the starter won't turn over or does the starter turn over but the engine won't start?
Old 08-21-2011, 02:13 PM
mray2686's Avatar
The starter turns over...but the engine doesn't start.
I actually just got it started. Will post another video when my buddy emails it to me.
I've been cranking it all day...and then this last time it tried it, we started.
- 1986 Porsche 911
Old 08-21-2011, 03:39 PM
Ah, I watched the video now.
I would get a multimeter, pull the main harness off the DME under the drivers seat, and test your sensors - mainly, the speed reference and TDC sensors.
Old 08-21-2011, 03:42 PM
mray2686's Avatar
And now she starts
So yesterday afternoon, after countless attempts to start, we get lucky. My buddy happened to be filming.
Nothing different as far as changes since that morning, which makes this so difficult to comprehend or explain.
Here is his video. Apologize for his cheer!
And now she starts... - YouTube
I called a local porsche shop because I want to have a keen set of eyes look her over. Over the phone today he mentioned maybe a faulty DME, or even a fuel pump.
My concern, at $90/hr, is that I bring it in a everything is fine...because I took her to and from work today, no problem, not even hesitant to start.
Got home after dark, so could not troubleshoot. Will get a multimeter and test as recommended. Any other suggestions? I'd love to try to figure this out and learn.
- 1986 Porsche 911
Old 08-22-2011, 06:00 PM
Spark? Pull a plug and check. Fuel? Try some starting spray in the intake. Then go from there.
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 08-22-2011, 08:33 PM
S ECU Repair's Avatar
My advice will be biased toward the DME of course, but I get DMEs from Porsche Targas at my office for intermittent no start all the time.
If the problem persists, tap on the DME, and see if the car shuts down while running, or if it starts while you are trying to crank it.
As Tippy said, also check those reference sensors at the DME harness with a multimeter (~1000 Omns). And physically look at them to make sure that they are clean, and in good condition.
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 08-23-2011, 06:30 AM
mray2686's Avatar
Thanks guys! I'll give these suggestions a shot and report back to you.
- 1986 Porsche 911
Old 08-23-2011, 08:49 AM
hi,
it could be ignition switch faulty, ie; when turning it to start position the ignition circuit is losing power hence the starter turns but no power to ignition or fuel circuit.
the DME relay holds two relay coils, when turning on ignition listen out for a faint click from under the drivers seat.
you can also bypass the DME relay by temporarily putting a bridging wire from the top of the 6th fuse in line [counting from left to right while looking at the fusebox under the bonnet/hood] to the 9th fuse from the left in line.
this will allow the fuel pump to run continous while the ignition is on.
hope this helps.
Anthony.
Old 08-23-2011, 12:11 PM
muck-raker
kidrock's Avatar
Sorry guys, I'm with Tigerrat on this one. Best to start from the beginning and find out if we've got spark and fuel.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-23-2011, 05:30 PM
mray2686's Avatar
I took the targa to work this morning. took a half second longer to fire the engine on first attempt, and I thought to myself I would have an issue tonight.
Leaving the office, I cranked it, and the engine wouldn't turn over, just like in the first post video. After about 7 tries, same result, I was about to catch a ride with a co-worker.
I remembered this post, and knocked on the DME while turning the key. Lo and behold, she fired up.
Got me thinking it IS a DME problem. How fast is the turn around for diagnostics?
- 1986 Porsche 911
Old 08-25-2011, 04:56 PM
RETIRED
Joe Bob's Avatar
As fast as the shipping company. Don't know anyone on the east coast, but Ingo can help.
3.6@cox.net
Old 08-25-2011, 09:16 PM
I cannot tell you how many times I see the same intermittent start problem with Targas every week...I can definitely help you out.
Send it over. I 'll test it for you, and let you know what I find.
www.ECUdoctors.com
1-800-328-1425
Old 08-26-2011, 06:01 AM
Lorenfb's Avatar
"it sometimes just doesn't turn over!"
And the DME ECM controls the starter on a 911 3.2, right?
Could also be the radio, as some Pelicans report a no-crank
situation when the radio was 'on'. Please!!!!!!!!!!!!!
"see the same intermittent start problem with Targas every week"
Right, it's always those Targas. Glad I never bought a Targa!
PLEASE!!!!!!!!!!!!!!!!!!!
"let you know what I find"
Right, and there's always some problem to be found.
And here's the typical result:1988 911 dme problem
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-26-2011, 07:11 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Swap out your DME relay with another known working unit.
AND:
If your DME relay is a ÜRO brand, replace it with a Bosch.
Lots of members have had ongoing issues with ÜRO products.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-26-2011, 07:22 AM
mray2686's Avatar
AND:
Good luck,
Gerry
Where do you see a Bosch relay? Mine is a ÜRO and I will replace. All I see here is the ÜRO and the genuine porsche DME relay.
- 1986 Porsche 911
Old 08-27-2011, 06:18 PM
mray2686's Avatar
Update - Still sporatic
OK - Been a few weeks, but I've done a few things to get to the bottom of this.
- Tune up. Replaced spark plugs, distributor cap, rotor. I have spark.
- Examined fuel filter. Was very dirty, replaced.
- Replaced DME relay, again.
- Had the ECM out, looked over by a pro. They reported back no issues with the ECM itself.
Put it all back together after tune up, and for the first few days we were running well without any "no starts."
Then, this week, it's back. Every time it has not started at first attempt, I've pushed back my seat, and with left hand turning key, right hand is knocking on ECM/wiggling ECM harness, and she will fire up...
I bought a multimeter today, have the Bentley manual out, and want to check if the harness is causing me these issues.
Problem is, I'm not really sure how to test this. Never used a multimeter. If anyone can talk me through this, I want to disconnect the harness in the morning and test to make sure it is all working well at the harness/ECM connection.
Am I looking in the right place? I find it so weird that if the car doesn't start right up, I've got to fiddle with the ECM, and then we are fine. SO Frustrating...
Thank you in advance for your help.
- 1986 Porsche 911
Old 10-01-2011, 04:23 PM
Lorenfb's Avatar
"Had the ECM out, looked over by a pro"
Pro??? 'Looking over' doesn't always find the problem!
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-01-2011, 07:31 PM
mray2686's Avatar
What would find the problem with an ECM?
Bench testing?
Swapping it out for a known good unit?
What do you recommend I do Loren?
Thanks!
- 1986 Porsche 911
Old 10-02-2011, 04:22 AM
Lorenfb's Avatar
"What would find the problem with an ECM?"
"Bench testing?" - NO
"Swapping it out for a known good unit?" - YES, with a lengthy test,
which I do often when conditions like this occur.
"I've pushed back my seat, and with left hand turning key, right hand is knocking on ECM/wiggling ECM harness, and she will fire up..."
Check here for additional info; www.systemsc.com/tshoot.htm
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-02-2011, 08:33 AM
