tassie targa 76's Avatar
does this engine number match this chassis number
G'day all
long story short my engine does not have an original number due to crankcase being replaced many years ago
investigation have suggested that the original engine number was 6361760
chassis number is 9116310836 obviously a 76 targa
this vehicle was sold out of Sydney and is Australian compliant RHD
if i can verify the original engine number i would like to reinstate it
any ideas
regards Michael
project 1976 911 targa
everyday drive 1995 318i BMW
wifes car 2001 c200 kompressor coupe
spare 2006 mazda bravo ute
Old 10-05-2011, 03:30 AM
twistoffat's Avatar
Hopefully this helps. You should have a 76 911 targa S
Fahrzeugidentifikation 911 1974-77
the small s.o means siehe oben (see above) referring to the line above. You need to be looking at the second line of the 76īs
Old 10-05-2011, 04:57 AM
It sounds like you have researched the original engine number and you'd like a confirmation, is that correct? If so, the only way I am aware of is to contact Porsche and get a Certificate of Authority which should include the actual engine number assigned to your particular car. I say "should" because after reading many threads about COA's, it appears the information can be questionable.
To answer your question in the title of the thread, yes, the engine number you posted fits within the sequence assigned to your car so, in that sense, it "matches." To determine if it is the actual number though, you'll have to get a COA.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-05-2011, 08:17 AM
