Am I missing something? Clutch replacement.
I have a 1980SC.
I am replacing the clutch. I have the engine and trans dropped. I have the 4 nuts removed from the trans that attach it to the engine. The trans will wiggle on the studs but will not come off the engine. What am I missing here?
Thanks,
Shelby
Once Upon a Time: 1980 911 SC Sunroof Coupe, 76 Turbo Tail, Bilstein Sports, Ruf-type bumpers, SSI's, Sport muffler, Wevo engine & Trans Mounts, OMP Corsica wheel, Momo hub
Old 10-05-2011, 06:29 PM
Oh Haha's Avatar
Need to disconnect the clutch fork from the pressure plate.
Pacific Blue
Wayne
Old 10-05-2011, 06:38 PM
efhughes3's Avatar
If you have your clutch arm assy off the shaft that is pointing straight down, the fork will turn and slip off the throwout bearing as you seperate them. If the arm and spring are still on, it wont.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-05-2011, 06:54 PM
Remove clutch position lever.......
To disengage the clutch fork, you need to remove the clutch position lever first. I borrowed this picture from another post. The clutch position lever with circlip is seen at the lower right of the picture.
Tony
Old 10-05-2011, 07:09 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
you dont have to remove the arm. just take a big screwdriver and move the big lever towards the front of the car until the omega spring snaps over center.
Old 10-05-2011, 07:16 PM
Awesome! I dropped the levers and replaced the spring in the past year, so they came right off tonight. The trans and engine split no problem. Thanks tons guys! Any need to know info on the clutch???
Shelby
Old 10-05-2011, 08:02 PM
fred cook's Avatar
SC clutch........
When I replaced the clutch on my SC, I used one of the Sachs Power Clutch kits with the aluminum clutch cover. It is quite a bit lighter than a cast iron cover, lets the engine rev a bit quicker and doesn't cost as much as a lightened flywheel. Be certain to use new flywheel bolts, assuming you are replacing the rear main seal while in there. You can make a flywheel holding tool out of a double boxend wrench (box end on both ends) by putting one of the cover plate bolts back in the flywheel and using one of the bell housing bolts on the other end. Effective and free! Good luck with your project.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 10-05-2011, 08:22 PM
80SC flywheel bolts are re-usable. It is a good idea to replace the rear main seal now.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-06-2011, 03:57 AM
Not to hijack, but how did you like the lighter clutch? Noticeable?
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 10-06-2011, 05:47 AM
fred cook's Avatar
Lighter clutch.....
I do like it! Makes the engine feel more responsive without being too sensitive on the bottom end. Not a huge difference, but noticible.
FEC3
Old 10-06-2011, 05:53 AM
Flywheel bolts (12 point) holding the flywheel on are not reusable as they are stretch bolts, like rod bolts.
The 9 8mm pressure plate bolts are reusable if the heads are still good.
Bruce
Old 10-06-2011, 06:17 AM
