-   -   OK to use a TORX 55 socket to remove flywheel ? (http://forums.pelicanparts.com/porsche-911-technical-forum/633413-ok-use-torx-55-socket-remove-flywheel.html)
JJ 911SC 10-07-2011 03:10 AM
Originally Posted by Bob Kontak (Post 6296498)
... My favorite parts store in Montreal was always Chez Paree.
That was my favorite buffet ;)
wildcat077 10-07-2011 03:15 AM
Still need to know what size triple square bit i need ... I measured the 55 Torx bit and it's 11mm,just need to confirm the triple square size ...
Cheers !
Phil
JJ 911SC 10-07-2011 03:44 AM
Phil
Its a 12 mm. I did not have to use air gum to removed them.
The trick is to be totally square off as the bite is very shallow.
I could ship you mine but thanks to Post Canada it would be cheaper to buy one.
http://forums.pelicanparts.com/uploa...1317984258.jpg
wildcat077 10-07-2011 06:06 AM
Hi JJ,
I ordered a 10 and a 12 from my local auto parts store,they're only $4.00 each so i'll be good to go.
Thank you for your consideration and the info!
I know you did an engine drop recently,any tips while i'm there !
Did you ever get your car back on the road this Summer ?
I have a crankcase gasket kit on the way so i'll be replacing whatever seals and "O" rings that come with the kit ...
Cheers !
Phil
JJ 911SC 10-07-2011 01:43 PM
Hey Phil
Yeah, finally got her on the road late August. Start on the second try, what a relief. The sound of the SSis mated to a 2In/2Out was worth the wait according to the guys behind me :D
Well might biggest tips is, resist the "while you are in there impulse" :) it could be expensive...
If you leak from anywhere, its a good time to fix them, especially the Oil Triangle of Death (crankcase breather, thermostat & the idiot light. Good time to change the Oil Idiot light, under $5.
Since you got a G50 transmission, the drop is straight down unlike with the 915.
Take a lots of pics and notes as you might not remember everything when the engine go back in.
Have fun
JJ
Mark Henry 02-02-2017 06:10 AM
Sorry to dig up an old thread, but if any Canadian peeps are looking for the tri-square bit/socket Princessauto (Canadian version of Harbour Freight) carries 4 different sets from $17. to $30.
SmileWavy
ChrisBennet 02-02-2017 06:25 AM
I have nice German ones (Stahlwille) but I was in a pinch
once and got some from my local parts place.
They don't have a socket that you could use a ratchet on.
Instead they have just a straight shaft; think of an Allen
key without the bend. You hold the non-triple square shaft
end with a socket.
They are apparently made of a structural cheese (soft).
They rounded over after a couple uses.
Not recommended.
http://forums.pelicanparts.com/uploa...1486045327.jpg
Driven97 02-02-2017 06:41 AM
I used this, <$7 at Amazon shipped. Don't know how I used to get by before internet shopping.
https://www.amazon.com/gp/product/B00ESN0032/
Mark Henry 02-02-2017 07:54 AM
If you do a lot of VW and Porsche work you need:
8mm, VW and 914 CV's
10mm, 996, flywheel and trans (I believe fly might be 12mm)
14mm, 911, flywheel, VW T4 auto trans flywheel (TC mount plate)
