OK to use a TORX 55 socket to remove flywheel ?
Hey guys,
I would like to know if it's allright to use a TORX 55 socket to remove the flywheel bolts.The Torx is a six point socket and it seems the bolts are 12 point and require a special socket ... Cheers ! Phil |
No!
Use the correct triple square |
If you strip it out it is a pain...you can get triple-square bits from sears.ca or Babco.
Thanks guys,
That's what i was thinking,just called my local auto parts supplier to order one ... Is it OK to use an impact gun to remove the flywheel bolts ? It worked well for the pressure plate fasteners ! Cheers ! Phil |
sure
Hmm, I've seen the correct tools for sale at several regular old auto parts stores.
Porsche wasn't the only manuf to use them. Maybe it's different up there, eh? ;) |
I've used a Torx to remove and replace my flywheel bolts a couple of times. No problems, just keep square to bolt head and lots of pressure holding it against the bolt.
Steve,
Not to worry,i found a set that i will be picking up after work tomorrow! Imagine that ! One cannot have too many tools :) I'm in the middle of an engine drop due to an exploding clutch and i caught the "while i'm there " syndrome ... lol Cheers ! Phil Cheers ! Phil |
You could always order them from Pelican Parts for $14.75 http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT332_pg12.htm Lisle 60750 http://www.northernautotools.com/med...nt-bit-set.jpg |
Good to know.
Napa is pretty common in Montreal. They have them.
J F MECANIQUE INC 2251 SAINTE-CATHERINE ST E, MONTREAL 514-521-4949 My favorite parts store in Montreal was always Chez Paree. |
Heat is your friend when removing these bolts. I use a propane torch to heat up the bolt (it doesn't take much) and they typically come right out. (using a triple square bit). W/O heat they are much harder to remove.
regards, al |
Can anybody confirm if i need an 11mm triple square bit for the flywheel ???
That seems to be the equivalent of a Torx 55 ... Cheers ! Phil |
I wouldn't touch these with an impact. Too easy to strip. With the flywheel locked down and a good-sized 1/2" ratchet or breaker, I've never had an issue to remove these. As mentioned, heat may be of assistance on those that need it.
Edit - nothing in the parts catalog that defines the bolt socket size with granularity. Also, the parts link provides nothing and the 901/915 clutch replacement provide nothing (tech info center) http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-102-206-00-M58&catalog_description=Flywheel%20Bolt%20%28sold% 20per%20each%2C%20%39%20req%2E%29%2C%20%39%31%31%2 F%39%31%31%20Turbo%20%28%31%39%37%38%2D%38%39%29%2 0 http://www.pelicanparts.com/techarticles/911_clutch_replace/911_clutch_replace1.htm (references "special tool") I remember it being 12mm. |
take a steel hammer & smack the bolt head flat on - i.e. normal to the axis of the bolt
http://forums.pelicanparts.com/uploa...1317962859.jpg |
when you say it like that...it sounds bad. |
| All times are GMT -8. The time now is 03:21 PM. |
