Kendall Transmission Oil question
Can I use Kendall 80/90 GL5 with LSD additive if I don't have LSD? Our host doesn't have the non LSD in stock.
Brian Anacortes, WA 81 SC |
Flat Six
Yes, you can
Dale 1985 Carrera 3.2 2013 Audi Q5 2.0T / 2005 BMW 325ci |
Keep the Shiny Side UP! Pete Z. |
Racer
....and you will be able to leap tall buildings in a single bound!!
![]() Scott |
Member 911 Anonymous
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
@ 3 digits
hahahahaha......for real ! it's that good....
'Enjoy the little things in life, for one day you will look back and realize they were the big things' |
after a lot of email traffic and lots of searching I decided to go with the Kendall in my 915 open diff....
I can honestly say, It's that good.....last week I leap two buildings in a single bound! pwned !
Ed M 86' Coupe |
The "leap" is not the problem... The sudden stop on the other side might be...
70 911T Sold ![]() 84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
LOL
brake upgrades are on the "other thread" ![]()
Ed M 86' Coupe |
RETIRED
It cured my herpes problem.....
Ooookay. Must be an inside joke that is over my head.
RETIRED
Consider the source.....I'm the resident sarcastic guy.
There is a 200 page discourse on Kendall versus Swepco. Hope it works for you.... |
abit off center
So how about Redline MT-90? Anyone have good luck with that in our cars? Its the "god" oil over on the VW forums!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Schleprock
If MT-90 behaves anything like their shockproof heavy weight gear oil, I would stay away. My '79 had shockproof in it when I bought it. Shifted pretty poorly- would get blocked out of 3rd quite often. Switched to something else and voila' it goes into 3rd every time ever since.
However I ran their 75W90 mixed with MTL or MT-90 (can't recall which) in my '92 AWD Laser w/Getrag trans and worked fine. Fine = shifted OK at all temps and the trans never blowed up in 50K miles. ![]()
Kevin L '86 Carrera "Larry" |
Just to be very clear...this special limited slip 80w-90 is ok to put in a non limited slip 915 transmission?
"Charlie don't surf!" |
Yes, sir.
What is the ZDDP level?
Gary R. |
abides.
just mix it 50/50 with brad penn and you'll be fine.
Graham 1984 Carrera Targa |
Does the Brad Penn need LSD additive?
Gary R. |
Taking it apart is easy
I use the regular non-LSD Kendall in my 915 open differential. I'm happy with the oil.
Why do you need the LSD additive?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
