Porchcar guy's Avatar
Cigarette Lighter socket insert
Saw a thread in the past 6 months that showed an "insert how" to for the lighter socket that allows use of modern equipment. Did not bookmark and now I need to do this..anybody ??
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 10-15-2011, 11:09 AM
try radio shack or just use some duct tape on the plug
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-15-2011, 11:52 AM
r_towle's Avatar
Get a cheap replacement lighter socket from walmart...this will be the American size.
All you want from the piece is the steel sleeve.
Cut off the electrical connector on the back and it will slip right into the european socket.
This fits perfectly and gives you the inner dimensions you need for your car adapter to work fine.
The thing I have used in a pinch is about one half of a business card folded over and jammed in one side of the adapter...
Rich
Old 10-15-2011, 01:20 PM
