Shot in the dark on window rattle
On my 88 930. I have a rattle that i think may drive me crazy and wondering if someone here can take a shot at it or at least point me in the right direction. I have had the door opener mechanism replaced as i figure it was those and the mechanic said it was but it is not. Prior to spending a bunch on it just looking for a common problem then will go from there. Long storey short when the window is up the rattle stops and when the window is down it is there. There seems to be no issue with the mechanism or the window function. Is there something else it coukd be?
I know this is a shot in the dark but thought i would ask prior to the 100 dollar an hour misdiagnosis again
Old 10-23-2011, 08:19 AM
RETIRED
Joe Bob's Avatar
Worn felt on the door top?
2012 ML350 3.0 Turbo Diesel
Old 10-23-2011, 08:21 AM
Wayah Road Warrior
Shadetree930's Avatar
I have had to chase door rattles in two different cars.
In both cases, it turned out to be the two screws underneath this door end-cap.
I know its a long shot ... but give it a try for your rattle.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 10-23-2011, 08:40 AM
my rattle came from the window track, there is an adjustment to the window guide at the bottom of the track causing rattle when the window was in the up position.
Old 10-23-2011, 08:48 AM
i had a rattle from two little metal plates that the door pockets screw into. For some reason these little plates are just in there loose. I think its the door pocket attachment point...i dont actually have door pockets. they are located here (see circles)...
76/3.0 tarcabvertible
64 corvette conv.
72 Alfa GTV
79 Jeep Cherokee Chief
Old 10-23-2011, 11:28 AM
kodioneill's Avatar
+1 ON This. Captive nut rattles when screw is loose or left out
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-23-2011, 12:27 PM
sorry there are three of these things each accepts a pair bolts/screws. i took a pic...
64 corvette conv.
72 Alfa GTV
Old 10-23-2011, 05:48 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Sometimes it could be the window coil retaining pin, mine broke but the window still works but when down it make a metallic rattle, when up, it stops. Need to replace but all works so I am being lazy about.
Noise doesn't bother me because the sweet sound of my engine over comes it
The other thing is, if yours is a cab or targa, the quarter window window guide mount at the bottom could fracture from closing the door at the window like most people do, I close my door using the handle always but my passengers use the damn window well it broke that L mount. It is remarkably fragile.
Jim
PM me your email address and I will send you the shop manual for the doors
'85 Carrera Targa
PCA/POC
Old 10-23-2011, 08:07 PM
