I would have to say that the door of any car, including the 911 is a huge sub cabnet. If it is properly ported and a speaker with plenty of power installed, it will thump. I have a small home sub that has a 6 inch speaker in it about 12X16X16 and it thumps quite a bit in a house which has more space than a 911. A good speaker builder can calculate a port size and tube length for your doors.
Also look at sunfire subs, very small, much thump.
Old 09-30-2002, 01:02 PM
Send a message via AIM to eurocarrera
Red face Subwoofer under the Seat?
Has anyone ever thought of mounting a speaker under the drivers seat? I have the stock seats, and if I remember correctly, there is almost 10" of space with the seat in the very bottom most position. Even if the speaker was touching the seat, that would be OK (it's only sound waves), and you would be able to allow the port to face front or rear. You would also be able to strap or bolt the sub to the floor with a few "L" brackest which would allow you an all over kind of sound.
Bill Atkins
mrpeabody37@yahoo.com
1985 Carrera Coupe ROW - SOLD
Old 09-30-2002, 02:23 PM
WydRyd's Avatar
Is this the Infinity self-powered unit you guys are referring to?
Features:
Built-in 200W Class D Amplifier
Remote Bass Level Control Included (BASSLINKLC)
10” Subwoofer with 10” Passive Radiator
Bass EQ -6dB to +3dB @ 40 Hz
Variable Crossover (50-100Hz) with 12 dB / Octave Slope
Verticle or Horizontal Mount Capability
2 or 4 Channel, Line or Speaker Level Inputs
Speaker Level Signal Sensing for Automatic Turn-On
Specifications:
Frequency Response: 20-120 Hz
Input Sensitivity Line Level: 50mV to 4V
Input Sensitivity Speaker Level: 1V to 16V
Fuse Rating: 25A
Dimensions: 14 1/2 L x 12 1/2 W x 8 D
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-30-2002, 04:45 PM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Yepper's... That be the one.. and I'm 100% satisfied with all the features.. including size. In my installation I removed the smugglers box lid and mounted it right above. This unit is perfect for my car. I removed all air conditioning components long ago.
and mounted in this location does not interfere with anything at all.
Jorge (Targa Dude)
Old 09-30-2002, 04:55 PM
Brian993's Avatar
Merv -
Do you have this unit installed? Does anyone? I would like to know if its any good. It looks like a nice compact unit! I am sure it costs a few $$ but if it works good it might be worth it.
http://www.p-caronline.com/directory/brian993
Old 09-30-2002, 04:57 PM
I had the bazooka, but the sucker sucked! I vote for the Infinity BassLink.
Awesome!
Old 09-30-2002, 05:05 PM
WydRyd's Avatar
Brian, I don't have a subby as yet
All my speaker components are factory units, however, I plan to upgrade to 6.5" Focal PolyKevlar's in the doors. I'm a bass fanatic, so I may go for the Infinity boot solution. It has had many great reviews, so I don't think you can go wrong.
FYI, Sounddomain.com lists it for $399.95 (USD).
Merv
'89 911 Turbo Cab
Old 09-30-2002, 05:07 PM
Brian993's Avatar
$400.00 dont sound bad! It is definetly the missing link to my sound system. This is probably the only set back to 911 ownership!
Old 09-30-2002, 05:08 PM
WydRyd's Avatar
Totally agree, the stock sound system in the pre-89 911's SUCK! I dunno about the later model 911's, mine just plain sux OK, there are times when I love to just listen to the roar of the twin tip exhaust, but sometimes I just wanna cruise and chill to some R&B
Merv
'89 911 Turbo Cab
Old 09-30-2002, 05:25 PM
Brian993's Avatar
The stock system (speakers) in the 993 are very nice and with the cd unit I had installed (alpine) its quite nice. Some bass would bring it right up to snuff! I am going to investigate this a litte further by stoping in at the local vendor seeing what he thinks. I am just concerned about installing it in the trunk and having it muffled.
Old 09-30-2002, 05:28 PM
diy83sc's Avatar
I have this one and have not yet wired it up.
http://www.epinions.com/content_51999706756
I can tell you it lay's nicely behind the driver or passenger seat (rear foot well) in my 83sc. It may not satisfy the audio critic, but should do better than the OEM speaker setup. I don't care to hack up the interior and prefer to leave in the factory 4x6 and 4 inch round grilles backed with some better speakers. If I need to, the kenwood can quickly disconnect by unplugging the connector. And if it doen't work out, I won't upgrade my headunit, visit ebay, and stick with the fine sounds coming from the exhaust
Tony
Old 09-30-2002, 05:35 PM
Targa Dude's Avatar
Hi Tony, That powered enclosure you mentioned is mostly a woofer the frequency response is way to high 35Hz to 1.5 KHz.. it's more of a mid range set up. Now the INFINITY is most definately a Sub.. with a Frequency Response of 20-120 Hz that is BASS!!! BABY!!
Jorge (Targa Dude)
Old 09-30-2002, 05:44 PM
Targa Dude's Avatar
Hey.. I found this picture.. sorry about the quality but, I think you can get a pretty good idea of how well it mounts in the forward compartment over the smugglers box
Old 09-30-2002, 10:13 PM
Yooyanks
yooyanks's Avatar
I put a kicker spec'd bandpass box in my porsche. It was 12x12 with an 8" solo baric woofer powered by a Rockford Fosgate punch 75. It sounded great!
Old 03-21-2012, 04:16 AM
You can go this way. Under- seat sub:
You can buy it here:
Kenwood KSC-SW10 (kscsw10) 150W 5" x 7" Powered Subwoofer Enclosure | eBay
For me it seems the best way to go.
1982 Black 911sc coupe
2000 Boxster S
2007 Harley Davidson Night Train (very customized)
1971 conv' beetle, 2332cc (sold )
Old 03-21-2012, 07:16 AM
Local Mad Scientist
Andy911sc's Avatar
I am also running this under the drivers seat. Very easy to install and fits nicely. I ran the controller up to the center console, also the cable is really long for that and I shortened it. I am getting a custom bracket to mount it up to the seat mounting bolts, so it's not sliding around.
Here is a picture of where it sits, minus the bracket yet.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 03-21-2012, 07:32 AM
crustychief's Avatar
Holy cow! a 10 year old thread!
BTW I have a bazooka on the floor behind the passenger seat.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 03-21-2012, 08:02 AM
Who you're gonna kill with this bazooka?
2000 Boxster S
Old 03-21-2012, 08:08 AM
Mr. C
SAY - 642's Avatar
Sub
I purchased one of these from Car Audio Innovations.
I'm very happy with it, they matched it to my blue carpeting, and it's pretty stealthy. I have a dedicated McIntosh MCC301 amp pumping 600 watts to it.
Porsche Audio
Old 03-21-2012, 08:18 AM
skunked's Avatar
do you have any motor noise? maybe not because it's a sub but I noticed you ran the power and RCA wires together.
-Mat
78 911SC
Old 03-21-2012, 10:31 AM
