rear flywheel seal removal, stuck
Hi folks,
I'm stuck on the rear seal - I can't get the old one out. At this point I've: -tried leveraging one screwdriver perpendicular to another one -drilled two holes and put in screws, then alternated pulling wit a wrench Any other tricks I should try? What about just drilling holes until it falls apart? There must be a better way. Babak |
get a longer screwdriver..really long
Bruce |
Your local generic autoparts store may have a seal removal tool. Looks kind of like a small medieval weapon - a handle with a hooked cross piece on the end. The hook you get under the steel shell of the seal, and using the handle you can pry. Pretty good leverage.
You don't want to score the case sealing surface, so you must be careful whatever method you use. |
Weekend Mechanic
Drill another hole and screw in a large sheet metal screw. Then clamp a pair of vice grips on the end of the screw. While holding the vice grips place the tip of a long crow bar under the end of the vice grips and use leverage to pry the seal out. Slow steady pressure is key. Just keep increasing pressure until the seal slides free. Make sure the hole you drill is just big enough the accept the screw. If it is too big the screw will just pull out.
J
86 911 Carrera Targa
Oil seal removal tool.........
The tool looks like these. ![]() Tony |
I used needle nose pliers to pull the seal apart, after the screwdriver method gave a little bit to grab onto.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
87 - 911
It is tougher than it looks, I struggled for a while last year when I changed mine.
I drilled a hole and inserted a bent nail (spike), clamped onto the nail with vise grips and pry against anything you have handy. As noted avoid beating on the inside and outside surfaces, don't want to mar the working surfaces for the new seal. |
These are great suggestions! I'll look for the tool, and try the techniques through the week and let you know how it goes.
Thanks, Banak |
Member 911 Anonymous
HB has one for $8 works great.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I'm looking at this puller right now:
http://www.amazon.com/Lisle-58430-Shaft-Type-Puller/dp/B000FPYW4K/ref=pd_cp_hi_0 I'll let you know how it goes! Babak |
FYI; use a Burr-Quick, or similar, tool to bevel the entry edge of the seal orifice before you install the new seal; this will prevent the case from tearing the new seal.
Keep the Shiny Side UP! Pete Z. |
in below link note slide hammer rig/vise grip rig to be used with screw insertion approach - no scarring of case.
flywheel/rear seal removal ...help. |
I started with the tool, and the clip at the end broke off. Fortunately it came with a replacement. I punched in the old seal at the notch per Peter's advice, and then used the replacement part with that tool to pull it out. Thanks for the help and advice! Now I'm working on getting a new one back in, about to try putting it in the oven at 250 for a while.
Thank, Babak |
Weekend Mechanic
You shouldn't need to put anything in the oven to install the new seal. It isn't a super tight press fit like a bearing. Deburr the leading edge of the opening if necessary as Peter suggests. Then hold the seal flush and level in the opening and begin tapping alternating edges with a hammer. Once the seal is holding tight in the opening you can use a ratchet extension as a drift and tap alternating points on the seal to drive it into place. A little Curil-T on the outside of the seal will help to ensure that no oil leaks happen in future.
You put the seal in the freezer, not the oven.
72 911 Although it is done at the moment, it will never be finished. |
