Heater options without heat exchangers?
What are some of the options in regards to maintaining heat for cars running aftermarket headers that don't have heat exchangers / heater boxes?
Well, if you have a AC compressor you reverse the flow through the evaporator and turn it into a heat pump.
SteveKJR "A Porsche does more then just go fast in a straight line" |
Do a search for Webasto or Eberspächer. They are gas heaters that are used for trucks to heat their cabs. Early 911s and the Yellowbird used them also.
Roland 930 Turbo '81 Too many modifications to list |
Some have added heated seats in place of heat. Just another option to think about
1985 Iris Blue M491 911 Coupe |
Thanks all. The Eberspächer looks like a neat solution.
So these just run off the battery right? |
No as the link says, it's a gas heater, burns fuel...
RETIRED
Not cheap.....runs off a siphon to your fuel tank. There are some electrical components, they all mount in the smuggler box. But doesn't have to.
Some AV aftermarket installs use the box.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Looking at the Harbor Freight flyer and they have a lighter plug in heater for cheap...in a pinch :=)
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Someone posted a fix by clamping a piece of exhaust tubing to the header, and then running the air through that. He said it worked well. Kind of like a home-made heat exchanger. Should be on this board somewhere.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
RV Heater and RainX for the glass works just fine.
Bill B. 63 Little B Coupe 67 SWB 3.63 Hotrod 08 Cayenne S 65 F100 |
závodník 'X'
This might not be the most elegant solution, but these little heaters are amazing. In the small cabin 911, you don't need much to heat and defrost. The problem is where to securely mount it?
Mr. Heater - America's Most Popular Portable Heaters |
+1 one for RainX but don't forget the RainX anti fog for the inside of the windows
RETIRED
Either HEs or a gas heater is about all your options. I spent two winters in No. Nevada....trust me. RainX is good for fogging windscreen.....
an electrically heated front screen is an option and popular in competition cars over this side of the atlantic due to the simplicity.
Harry Hockley Motorsport in Wales (UK) is listing them for 911s. Do a google search on hhms. I haven't seen these windscreens but I can vouch for Hockley's normal quality in the parts I have seen supplied- he builds proper competition rally cars for works teams. There are other suppliers as well. Try heated windscreen as a google search. |
Did an internet search and a number of vendors in England and one here I saw..$675 for it in 2009
ProSource Glass International PO Box 996 Andover, MA 01810 Tel:877-345-2800 978-975-5400 Fax:978-975-5300 Email:richardt@prosourceglassintl.com
typical prices on this side of the pond for heated laminated front windscreen seem to be GB pounds 205 ( evans motorsport) GB pounds 215 (Hockley motorsport) both plus vat( value added tax 20%) but as its for export from the EU they shouldnt be charging you vat.
The freight might be interesting however? just another option. let us know what solution you come up with. |
