Imperative that I connect the O2 Sensor on my cat bypass
Hey guys,
I recently installed a Bursch Cat Bypass and muffler to my 83SC. When we pulled the sensor through the sheet metal, it came out as if it was never plugged in at all. I capped the bypass O2 bung and did not install the O2 sensor, as I could not get it out of the original Cat. It is pretty well rusted in there. Shall I buy a new one and install or is okay without it. Please let me know and thank you for your time. Greg
Porschephile for life!!! |
Fleabit peanut monkey
Buy a Bosch universal at the local parts store for $20 and use it.
Autozone (619) 702-9461 2211 Imperial Ave, San Diego, CA 92102 http://www.autozone.com/autozone/parts/Bosch-Oxygen-Sensor/1983-Porsche-911SC/_/N-iv0llZ8gcvp?counter=0&filterByKeyWord=oxygen+sensor&fromString=search&itemIdentifier=4966_54956_5320_ Last edited by Bob Kontak; 11-02-2011 at 06:42 PM.. |
RETIRED
Drill a hole, weld a bung, install the sensor.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
My Bad.....
Thanks guys. It is just capped with a bolt right now so I can easily remove and add a sensor. I will take a look at this bosch setup. Thanks Bob
Member 911 Anonymous
If it is a 3.2 you can install a Bosch O2 sensor for a '96 Ford Taurus, just splice it.
Make sure you have the proper amount of wires on the sensor.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
