Imperative that I connect the O2 Sensor on my cat bypass
Hey guys,
I recently installed a Bursch Cat Bypass and muffler to my 83SC. When we pulled the sensor through the sheet metal, it came out as if it was never plugged in at all. I capped the bypass O2 bung and did not install the O2 sensor, as I could not get it out of the original Cat. It is pretty well rusted in there. Shall I buy a new one and install or is okay without it. Please let me know and thank you for your time.
Greg
Porschephile for life!!!
Old 11-02-2011, 11:58 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Buy a Bosch universal at the local parts store for $20 and use it.
Autozone
(619) 702-9461
2211 Imperial Ave, San Diego, CA 92102
http://www.autozone.com/autozone/parts/Bosch-Oxygen-Sensor/1983-Porsche-911SC/_/N-iv0llZ8gcvp?counter=0&filterByKeyWord=oxygen+sensor&fromString=search&itemIdentifier=4966_54956_5320_
Old 11-02-2011, 06:38 PM
RETIRED
Joe Bob's Avatar
Drill a hole, weld a bung, install the sensor.
2012 ML350 3.0 Turbo Diesel
Old 11-02-2011, 07:07 PM
Bob Kontak's Avatar
Joe Bob - I tole you not to go there. Read the pacifics. You didn't listen.
Old 11-02-2011, 07:23 PM
RETIRED
Joe Bob's Avatar
My Bad.....
Old 11-02-2011, 07:31 PM
Thanks guys. It is just capped with a bolt right now so I can easily remove and add a sensor. I will take a look at this bosch setup. Thanks Bob
Old 11-02-2011, 08:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If it is a 3.2 you can install a Bosch O2 sensor for a '96 Ford Taurus, just splice it.
Make sure you have the proper amount of wires on the sensor.
'85 Carrera Targa
PCA/POC
Old 11-02-2011, 10:54 PM
