Heater options without heat exchangers?
What are some of the options in regards to maintaining heat for cars running aftermarket headers that don't have heat exchangers / heater boxes?
Old 11-01-2011, 01:04 PM
stormcrow's Avatar
Well, if you have a AC compressor you reverse the flow through the evaporator and turn it into a heat pump.
SteveKJR
"A Porsche does more then just go fast in a straight line"
Old 11-01-2011, 05:12 PM
Do a search for Webasto or Eberspächer. They are gas heaters that are used for trucks to heat their cabs. Early 911s and the Yellowbird used them also.
Old 11-02-2011, 03:44 AM
proffighter's Avatar
I fitted a gas heater from Eberspächer:
Gas heater installation
Roland
930 Turbo '81 Too many modifications to list
Old 11-02-2011, 04:49 AM
oh snap's Avatar
Some have added heated seats in place of heat. Just another option to think about
1985 Iris Blue M491 911 Coupe
Old 11-02-2011, 10:45 AM
Thanks all. The Eberspächer looks like a neat solution.
So these just run off the battery right?
Old 11-02-2011, 01:57 PM
No as the link says, it's a gas heater, burns fuel...
Roland
Old 11-02-2011, 03:24 PM
RETIRED
Joe Bob's Avatar
Not cheap.....runs off a siphon to your fuel tank. There are some electrical components, they all mount in the smuggler box. But doesn't have to.
Some AV aftermarket installs use the box.
2012 ML350 3.0 Turbo Diesel
Old 11-02-2011, 07:07 PM
Porchcar guy's Avatar
Looking at the Harbor Freight flyer and they have a lighter plug in heater for cheap...in a pinch :=)
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 11-02-2011, 08:14 PM
na2ub's Avatar
Someone posted a fix by clamping a piece of exhaust tubing to the header, and then running the air through that. He said it worked well. Kind of like a home-made heat exchanger. Should be on this board somewhere.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-03-2011, 08:24 AM
Many have tried this and didn't have much success keeping the windshield de-fogged.
Old 11-03-2011, 09:26 AM
Wilywilly's Avatar
RV Heater and RainX for the glass works just fine.
Bill B.
63 Little B Coupe
67 SWB 3.63 Hotrod
08 Cayenne S
65 F100
Old 11-03-2011, 11:30 AM
závodník 'X'
intakexhaust's Avatar
This might not be the most elegant solution, but these little heaters are amazing. In the small cabin 911, you don't need much to heat and defrost. The problem is where to securely mount it?
Mr. Heater - America's Most Popular Portable Heaters
Old 11-03-2011, 02:20 PM
+1 one for RainX but don't forget the RainX anti fog for the inside of the windows
15 year PCA member
Old 11-03-2011, 02:34 PM
RETIRED
Joe Bob's Avatar
POS and waste of money.
Either HEs or a gas heater is about all your options. I spent two winters in No. Nevada....trust me.
RainX is good for fogging windscreen.....
Old 11-03-2011, 02:41 PM
an electrically heated front screen is an option and popular in competition cars over this side of the atlantic due to the simplicity.
Harry Hockley Motorsport in Wales (UK) is listing them for 911s.
Do a google search on hhms.
I haven't seen these windscreens but I can vouch for Hockley's normal quality in the parts I have seen supplied- he builds proper competition rally cars for works teams.
There are other suppliers as well.
Try heated windscreen as a google search.
Old 11-03-2011, 02:54 PM
Did an internet search and a number of vendors in England and one here I saw..$675 for it in 2009
ProSource Glass International
PO Box 996
Andover, MA 01810
Tel:877-345-2800
978-975-5400
Fax:978-975-5300
Email:richardt@prosourceglassintl.com
15 year PCA member
Old 11-03-2011, 03:08 PM
typical prices on this side of the pond for heated laminated front windscreen seem to be GB pounds 205 ( evans motorsport) GB pounds 215 (Hockley motorsport) both plus vat( value added tax 20%) but as its for export from the EU they shouldnt be charging you vat.
The freight might be interesting however?
just another option.
let us know what solution you come up with.
Old 11-04-2011, 04:28 AM
