Cold weather projects?
Now that the driving season is wrapping up for most of us, what are your winter projects going to be? I've got brakes to replace, exhaust to upgrade, oil change and valves.
What about you guys?
The Uncertainty Principle. It proves we can't ever really know...what's going on. So it shouldn't bother you. Not being able to figure anything out. Although you will be responsible for this on the mid-term. -Larry Gopnik |
I got new parts for the tunnel fuel lines and CHT.
oh yeah, one more oil leak to track down - it could be the cooler seals.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Fleabit peanut monkey
81 SC
Fix hard-to-get-to small air leaks in back of air box Put my Boxster Brake upgrade kit back on with Porterfield R4 pads. Replace flex brake lines. Install cross drilled rotors on rear (have had them for a few years) Adjust valves Replace one leaking oil line at engine and maybe the two at the front cooler (I see little cracks and some slight seepage) Respray driver's rear quarter with 22 line - (I can just see primer through paint in the right light in one area - the area easiest to power buff :-)) Decide what to do with original leather seat bottom on drivers side. Showing age and stitching is coming apart Have steering wheel recovered professionally Targa top to Dan Pechtel and get the correct front and rear seals. Fix center vent plastic feed tube gasket - only rattle in car (when the top is not on) Lift front end a bit. I over did the lowering a few years ago. Alignment. Better align door windows New carbon canister hoses Passenger window motor replace Have fuel pump rebuilt and replace check valve. Put Schnorr washers and moon plates on CV joints. |
Adjust valves, install new valve cover gaskets, replace the fuel filter, repaint my wheels. If the budget allows, I really want to rebuild my steering rack. I've maintained it but wnat to get it apart and do the full boogie on it.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
The dreaded headliner in a sunroof coupe. Any tips are welcome.
Garmo '80 911SC |
FWI, the windshield needs to come out for headliner removal/installation.
I need a new one but it will have to wait until I need a new windshield.
RETIRED
Paint and new graphics....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Headliner.......
Not just the windshield. All of the glass (except door windows) will have to be removed. If you are doing the job yourself, get several boxes of the black metal spring clips (normally used for paper). With the clips, you can position the headliner, decide if it's "right" and adjust where necessary. Then, take one section loose, apply the contact cement and clip back into place. Repeat until each edge is attached. One of the last jobs will be to cut in the interior lights. Make certain that you are cutting in the correct place! A mistake here means starting all over again. The sunroof inside cover will have to come out which usually means removing the sunroof panel. Last, reinstall the glass using new seals. The side quarter windows will have to be reinstalled by inserting the front edge first and then roping in moving towards the rear (pointy end). Be certain that the outside window trim does not pop out of the rubber seals. Good luck!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Carrera footwell blowers. Finished this yesterday in my nice warm garage. My SC now has hurricane force heat and defrost. This is a cold weather project on multiple levels I think.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I want to replace the top on my Cab this winter!
1985 Triple Black Cabriolet-ROW**Sold** 2008 Cayman S Guards Red/Black 2007 Audi A4 2.0T Red/Black |
I want to drive mine - but will do what it takes to keep it going.
maybe new air in the tires
Ed M 86' Coupe |
78SC
going to happen: -New rear suspension bushings and possibly torsion bars. -paint calipers -rebuild brakes -heater blower motor -heater hoses and valves -paint fan and housing -fix rust under battery Possibilities: -targa body braces? -short shift kit? And i have 3 weeks of winter break to do it all.
David Colangelo "Porsche Accept No Substitute" 78' 911 Targa 88' 924s 31' Ford Model A |
82 SC
Transmission rebuild Full suspension set up tracking down god knows how many rattles maybe some Misc interior stuff depending on how much of the winter is left. |
I'm going to have to go with a RennShift shifter and a Moroso sump vent catch canister.
This is my list:
1. Wevo shifter and coupler 2. Clutch cable and assorted springs 3. Full suspension rebuild with Sanders bars and Elephant Racing goodies. 4. Tune-up and valve adjustment Going to start as soon as the road salt hits the pavement, here in Chicago. Should make for a great driving season next year. I'll post my progress. Dean |
83 911 Production Cab #10
Left over of last year Winter/Spring/Summer (Dec-Aug) projects...
Full brake job (lines, disks, pads & shoes); Short Sift Kit (to mate with the new clutch & flywheel); Cosmetic (new piping & belows); and maybe Cut off muffler switch ( but (apparently) the SSIs & 2in/2out combo sound so good that I may wait until I see the blue lights in my mirror. So far so good
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Ewerything.
Car is new to me. Had it fore 5 month. Jocke. |
Front end polybronze , balljoints , TT rods ...but wait , it's summer next month? Need to get these fixed this weekend , so I can use Le Frog over next winter
Install snow tires
Tired Member
Still working on last winter's project.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
