Could this be an ECU problem?
Got an intermittent engine stalling problem and traced it up to a 'no spark' condition. My wrench said it may be caused by intermittent disconnection in the electric circuits.
Acceleration was fine, no hiccup or flat spot and no abnormal fuel smell but usually one or two minutes before the engine went out I noticed the engine response and output was less than ideal. At least on two occasions the engine went out after marked road undulation, maybe just a coincidence. The crank sensors should be fine as I have replaced both a couple years ago. The ECU was serviced less than 1000 miles ago in another garage but I was not told what went wrong except that a part inside was replaced with a used good one. Could this be an uncured ECU problem or failure of the replaced part? Thanks for looking and appreciate any advice!
'87 3.2 Targa |
Member 911 Anonymous
To be certain you need another to compare to but I am thinking it may be your reference sensor, have your wrench test both speed and reference sensors.
Bentley shows what the OHMs should be.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hi, long time no see
![]() Both sensors were replaced by myself not many miles ago so I guess they should be fine. And if I remember it right only the speed reference sensor would cause engine stalling while the other causes no starting.
'87 3.2 Targa |
Oh hey Brother!
When you installed it, did you at all twist it in? I hope not, that will kill the sensor. If you can borrow some a 3.2 DME that will eliminate that as a suspect. Jim
Also check your plugs, cap and rotor and ground points
Don't remember twisting the sensors in, they were not very difficult to install once you got under the car. I replaced the CHT as well.
Grounding is a suspect, too. Actually am thinking of sending the ECU to Steve Wong for a service and new chip.
'87 3.2 Targa |
Sounds like the classic problem of cracked solder joints in the DME. Open it up and inspect the ones that stand up from the board, as they put a lot of strain on the solder joint.
Search the archives, there is lots written on this. Hope this helps, Chuck.H '89 TurboLookTarga, 327k miles |
The answer is yes. The DME can fail intermittently as others said because of poor solder and cracked joints. Best to get a loaner and check if the problem goes away. Depending on how good you are with electronics you could fix this yourself.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
"after marked road undulation" ?? I did not understand what this meant after reading your thread??
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
I wouldn't "guess the sensors are OK", at all.. Best check them, again....then, head to other areas,....you have to know NOW that they're operationally OK..
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Thanks guys! I'll check the DME and sensors!
With "marked road undulation" I mean the road runs up and down in a very short distance.
'87 3.2 Targa |
![]() Also check your dizzy, have your wrench remove, note position, check for slop, laterally and axial. Mine had both in slop and it caused a miss fire between 2-3K RPMs. Due to the axial slop, my internal snap in bearings were shot, there are no replacement parts for this. I purchased a known good used one. It spun with some resistance and did not slop up or down (laterally). Good news is if you only have lateral play then you can ad some SS shims/washers to take out the play. Make sure it is properly lubed. ![]() Click Pic Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 11-15-2011 at 04:29 PM.. |
Thanks mate! I did lube the dizzy myself but have not pulled it out for inspection lately. Think it a good idea to check even it's not related to stalling.
Sounds like when there are no longer any good used dizzy available our toys have to rest in peace
'87 3.2 Targa |
