Diamond911's Avatar
solvent to remove engine sound mat old orange glue?
Hi guys,
As the topic states. Removed my old original engine sound mat as it was crumbling to pieces all over the engine.
What is the best solvent to remove the old orange glue left behind?
thanks
1988 911 3.2 Carrera (Commemorative Edn), 1988 928 S4
Old 11-19-2011, 10:33 PM
haycait911's Avatar
if you can keep it soaked in lacquer thinner long enough it would work. or, if you can sacrifice the paint, automotive paint stripper or spray gasket remover. solvent might do the paint anyway.
Old 11-19-2011, 10:52 PM
cdrik915's Avatar
I removed the "Neoprene" with White-spirit.
Perfect result.
LIGHTER = FASTER !!!
Old 11-20-2011, 03:14 AM
Two Rivers's Avatar
What is white-spirit.
Mineral spirits?
Old 11-20-2011, 05:45 AM
Recreational User
porschenut's Avatar
Heat gun and a metal scraper?
Old 11-20-2011, 06:33 AM
Personally I wouldn't use a metal anything (scratches). Heat would be good... I used Goo Gone and rags and a LOT of elbow grease...that glue is nasty stuff to remove. I know there are more effective solvents, but I didn't want to remove any (more) brain cells . Since the OP is in the Diamond Blue club, here's an incentive:
ps: I forgot to add...a partial engine drop allows for easier access.
Old 11-20-2011, 07:29 AM
I used Goo-Gone Gel for mine (with engine out). It's tacky enough to spray on and stay on vertical surfaces. I let it soak a couple of hours and then removed with a stiff brush, rags, and then some Simple Green and water. It didn't appear to hurt the paint.
Old 11-20-2011, 08:10 AM
cdrik915's Avatar
Mineral spirits?
It's a solvant , usually used in paint work or to wash the tools after painting.
It's not agressive.
Old 11-20-2011, 08:44 AM
Wash. State
nesslar's Avatar
My brother just removed a bunch of stubborn glue from his car using penetrating oil and a lot of elbow grease. I've seen the result, no paint damage and the goo is gone. best to wash it off right after words, of course. YMMV, but his paint looks great in the area 'treated'.
Old 11-20-2011, 10:34 AM
j911brick's Avatar
Pressure washer does a good job and long as your paying attention and not getting too aggressive because it will also remove the undercoat.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 11-20-2011, 11:03 AM
Diamond911's Avatar
Thanks for the replies guys. Thanks for the photo as well KC, great work, and always nice to hear from a fellow CE owner.
Getting ready for a concours this coming Sunday. Shame to lose the original engine mat but no point in having something in the engine bay that is falling apart.
Old 11-20-2011, 06:12 PM
French Import
zippy_gg's Avatar
You can use Citristrip found at Home Depot. It worked great to remove the glue form the old carpet inside my cab and should do just fine on your sound mat.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 11-20-2011, 08:26 PM
brake cleaner will take it right off with out damage to paint underneath. spray on and wipe off, simple as that.
Old 11-21-2011, 08:24 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
This is what I used when replacing the sound mat.
Cheers,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-21-2011, 08:28 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I do know that Acetone is wrong. I did what j911brick did - used a pressure washer but bought a gallon of "Adhesive Remover" from Lowes. Worked great in combination. Probably about the same strength as the Citrusstrip. Never tried the 3M product.
Probably a high pressure nozzle - one of those that is a single brass piece - on your hose with one of the correct strength strippers would do the trick as I stayed pretty far back with the pressure washer.
Old 11-21-2011, 08:37 AM
MAGA
Tim Hancock's Avatar
Scrape off what you can and simply glue on a new sound mat.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 11-21-2011, 08:42 AM
I tried a few things including goofoff, ended up "rolling" it off using pieces of rubber.
Old 11-21-2011, 09:39 AM
Taking it apart is easy
Jerome74911S's Avatar
3M General Purpose Adhesive Remover works, but wear an organic solvent filtering mask, lest you dissolve your brain, also.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 11-21-2011, 11:06 AM
AutoBahned
RWebb's Avatar
1st - just use a plastic or wood scraper
2nd - pressure wash if the motor is out - be careful of all electrical items & hoses for oil or air, etc. left in the area
3rd - Stop. Decide how pretty you want it to be. If you are putting up a new sound pad, just do that.
Old 11-21-2011, 12:26 PM
Do not remove the glue from your car. Glue ~20 small round magnets to the back of your new sound mat and magnetically stick it to your car. I did this to my car and it looks like you glued it in
Old 11-21-2011, 03:39 PM
