Strange problem after degreasing bottom of engine - starter stuck on
'74 2.7 CIS
I cleaned the bottom of the engine and transmission today. I sprayed everything with degreaser and let sit for a few minutes and then hosed off with hot water. It did such a good job but there was still some grease so I did this a few times.
Afterwords, I started the engine and everything was fine. Later in the day, I started the engine and the starter kept running. I turned off the ignition and the starter would not stop running. I had to disconnect the battery. Afterwords, I connected the battery and everything was fine....but it did it again when I started the engine.
I tried one more time and everything was back to normal. Is it possible that water could make a circuit (enough to keep the starter engaged)?
Since I detailed the car today, I was bent on taking the 911 to thanksgiving and so I drove the car but I was worried it would do it again but it didn't.
I'm guessing I need to get up under there and check all my connections and the condition of the wire but I'm open to suggestions.
Thanks..............Vern
Old 11-24-2011, 11:31 PM
cdrik915's Avatar
A common issue : the solenoid stay engaged after starting.
It can happens sometimes.
But it can also means that the soleinoid is old.....or has a problem.
LIGHTER = FASTER !!!
Old 11-25-2011, 12:24 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Solenoid stuck.
Raise the car safely with jack stands check the contacts and trans ground then once cleaned then start her/ If still running then use a piece of long wooden dowel and smack the Solenoid to see if it will un-stick.
You may need to eventually remove and service or replace it. I removed my starter and serviced it since it was making a screeching noise. Cleaned and lubed and replaced, No issues and starts on instantly.
Jim
'85 Carrera Targa
PCA/POC
Old 11-25-2011, 12:45 AM
Engineer of profanity
924CarreraGTP's Avatar
My '70 2.2 T did this when I first started trying to get it running. It stopped doing it after I drove it and it works fine now. Once in a while it will stay on for a minute and then quit. The water may have caused it, but I would let it dry out really good with a good drive and see if it stops. The heat of the motor will probably dry it out eventually.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 11-25-2011, 03:18 AM
cdrik915's Avatar
You're probably right.
Sometimes , the solenoid contacts are burned , you can try , in this case , turning them.
That permits sometimes to save it.
Old 11-25-2011, 04:25 AM
Everything went back to normal once I drove the car and got it really dry. I may consider a new starter at some point but for now it's working normally. I will get under there and check the condition of all wiring - just for piece of mine.
Another thing happened...My heat exchangers must have gotten water in them as the windows fogged for about 45 minutes. I had to drive with the fresh air blower on or the windows would instantly fog up. I guess water entered thru the flapper boxes.
I've only had this car since Oct 1st so I guess I'm not used to aircooled quirks....but I will learn.
On the brighter side....my car is really, really clean now.
Old 11-25-2011, 09:21 AM
DRACO A5OG's Avatar
LOL, yeap, 911 and water do not mix
When I degrease and rinse, I drive for about an hour to insure it is completely dry.
If I may suggest, degreasing will also get rid of much needed lubricant on the clutch spring/shaft assembly and gas pedal linkage (especially at the #3 intake manifold). I would consider cleaning and lubing them as well. Especialy the clutch fork shaft, this is the most neglected.
Jim
'85 Carrera Targa
PCA/POC
Old 11-25-2011, 11:39 AM
