Senior Member
Removing "Flag style" door mirror wiring harness
Well have finally decided to paint the car and need to get the "flag style" mirrors off of the car to do it right.
Got the mirror's themselves off but then realized that the wiring harness goes all the way inside the car "somewhere!" Has anyone ever done this and know where all of the wires go? I am not sure if I am going to keep them on the car but even so just am not a "cut the wires" and forge ahead person. Would rather find the harness and pull the plugs so that someone else could use them if needed. TIA, Joe A
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
RETIRED
The harness and connections are under the door panel.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I think you have remove the pins from the plug to do it right. Most people just cut the plug off I think.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Senior Member
Mike,
I pulled the door panels off (need to re-do them in a different color) and tried to find the harness and they seem to go inside the car in the door jam. Do you think that there is a plug that I can disconnect to remove the mirror inside the door? thx, Joe
RETIRED
That's what the Bentley says.....but cutting and reconnecting with m/f buttend plugs is easy.
I removed the the harness all the way to the fuse block...just trace it out, it is not that hard. Door panel off, through the door post and into the trunk...less wire = less weight, don't forget about the fuse. Once you remove the mirrors...who would need them? And if they do wouldn't they just wire them up themselves?
Jeff |
Removing Flag Mirrors
if you scroll through the post:"Flag Mirrors Gone" you'll find what you're looking for on page 6 and 7
Flag mirrors gone - welcome Vitaloni Sebring Mach 1 Mirror
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories Last edited by Mitch Leland; 11-28-2011 at 09:31 PM.. |
Wine User
mirors
I just did mine. I pushed the connectors out to be able to pull the wires through the small hole. Be sure to note the wiring on the plug (the plugs have numbers on each position. The wiring diagram is in the Bentley.
Luck |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Mirror Harness.
Pull the pins/document-color to pin#.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Insert Tag Line HERE.....
Yes, the correct way is to pull the pins out of the connector and pull them through the mirror base. That will get you mirror off. If you want to remove the harness, you can pull it through the grommet at the front of the door. It connects inside the hood near where the hood shocks mount. If you open the door and look underneath the part of the front fender that extends back, you can see where the harness goes through the body. It is looped back 180 degrees.
Senior Member
Perfect guys!
Now that I know how to take the mirror off to get to the connector, will do that. I do not mind leaving the harness in the car/door, just want to get the mirror off of the door so that we can start sanding and painting! Thanks!
