Exhaust nut torque
I have just refitted headers and muffler to my early mag case engine and torqued everything to spec, but the exhaust is leaking quite badly.
Should I go higher than the recommended 25NM or should I use some sort of exhaust paste ? |
Schleprock
Don't use paste. That stuff turns rock hard and is a real bear to clean up.
Try loosening and re-tightening the offending parts. On headers I like to start with the middle pipe first, tightening from the center outward.
Kevin L '86 Carrera "Larry" |
Member 911 Anonymous
Are you certain your torque wrench is calibrated properly? You did crisscross pattern to evenly mount the component?
+1 no paste.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I am assuming you checked the surfaces carefully. How about gaskets? I think the double metal sided gaskets that our host sells are the trick, not sure if they fit the earlier cases?
Also, confirm its leaking at the head to exh header seal. Can you show us a pic of how you have have it bolted up to the head (installed header pic - up close to one of the cylinder head/header interfaces)?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Capitalist and Patriot
I just did a full R&R of engine trans exhaust etc... When I started car had massive exhaust leak somewhere... I let the engine warm up anyway and most of sound went away. That told me I needed to remove HE and file the flange faces flat. When I got the HE off I could see where the hot gases blew by the gaskets.
I used flat files on all flanges on each HE to head surface as well as cross over pipe. That did the trick. Evidently these surfaces erode over time and need to be trued up! All good now. 18ftlb torque on HE flange to heads. Check yours out. Just a suggestion. I don't think over torqueing will fix your problem. |
Senior Advisor
what brand headers, some off brands might never seal
08 Cayenne Turbo |
excellent info...just fired up my 3.0 and have similar exhaust issues...will pull the hxchgers and dothe same...
The worst leaks are at the heads and the headers are actually factory HEs with the outer tin cut away.
I've already filed the surfaces flat and I fitted everything loose to start with and tightened up gradually. The gaskets are from our host, would it help to use two gaskets sandwiched together ? |
You have leaks at the heads after filing the HE flanges flat? Flat across mounting holes? If so there shouldn't be any leaks from that area. Wouldn't hurt to use two of the metal mid year gaskets but I don't know how this would help if already flat from flange mounting hole to flange mounting hole. Did you use a metal straight edge to check/verify they are perfectly flat?
