Originally Posted by Jim Williams View Post
Sherwood -
I think others recommended to take your approach. I certainly wasn't suggesting to use a tap. It was just a warning for those who for some reason might take the advice of others to use one. My thoughts are that a tap should only be a last resort if the internal threads are too hopelessly buggered up to accept the bolt, and then only as a chaser, same tap size as the bolt, not a larger thread. My point was (or should have been) that a cross-threaded tap might be worse than a cross-threaded bolt.
Jim,
My statement not directed at your comments but as, just another.
Sherwood
Old 12-05-2011, 04:51 PM
too many projects 1983 sc
56 nomad's Avatar
Originally Posted by nilknarf View Post
For anyone struggling with this in the future, when I went to bolt my engine/tran in place, the first thing I did was to loosen the trans mount plate so I could wiggle it by hand, then jacked the engine/trans into position and used a phillips screwdriver to adjust the alignment betwen the mounts on the trans and the mounts in the car. Once I had the trans bolted in, THEN I movd to the motor mounts at the back of the car. Once all the motor mount bolts were tightened down, then I snugged up the forward trans mount plate. Piece of cake!
Curt
+1 on that everything a little loose then tighten. regards , ben
Old 12-05-2011, 05:03 PM
Walt Fricke's Avatar
And the good news is: when you hopelessly cross thread the mount, you can repair it with a Helicoil. Many, many 911s have at least one of these repairs to this area.
I don't recall that these are a non-standard thread, though. Otherwise Helicoils would be hard to come by. Or replacement bolts, which I have purchased.
You need to repeat the mantra: it came out OK, so it should go in OK, so I will, under no circumstances, apply any real torque to get the bolt started.
Easy to say. Frustrating to put into practice.
Old 12-05-2011, 05:54 PM
