Why do sway bar mounts tear?
Is it just cornering loads, or are the getting snagged off road?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Stress loads from cornering. The mounts were barely good enough for o.e. bars on SCs/early Carreras, but their weakness was obvious with the bar size change in '86.
Keep the Shiny Side UP! Pete Z. |
MBruns for President
and bigger, stickier tires...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thats what I initially thought. Reading all these threads about it had me wondering if there was some way to relocate the bar out of harms, way, but if most believe it is just the cornering loads, then I guess I am good with just beefing them up.
I can go back and tune in to that thread. Thansk!
After years of metal fatigue something has to give.
Porsche Owner
now is there a solid fix to this issue or we just have to reweld?
1987 Carrera - 2008 Cayenne Turbo |
Several "fixes" out there (even Porsche came out with a better part-"butterfly").
I have a driver side rear cracked, at present and have the WEVO's in hand to install (both sides-ahem) It will certainly require "welding"!!!!! Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Sherwood |
Platinum Member
To me, it seems like those that stiffen the sways without stiffer shocks and springs tear out the mounts.
I had a '77 100% track use, with stiff torsion bars and custom valved struts/shocks that was fine with the stock swaybar mounts. |
Hmmm, that's interesting. Do you suppose that there was less force applied to the sway bar because more was taken up by the suspension?
Look at the later car's torsion bars.....larger, no?
Doyle
22mm and larger sway bars, 300+ lbs. more chassis weight and wider wheels/tracks widths play a factor. Earlier 911s typically don't carry those specs., not to say the mounts are foolproof, just adequate for most early cars.
Sherwood |
I found it interesting that Porsche acknowledged this having come out with the replacement butterfly mounts (Porsche part) (again).. even through 1989,.....These WEVO's will put an end to any further sway bar issues........
Assured, early ones didn't carry the larger sized torsion bars.... Best! Doyle
I used the Buckley rear mounts. They will outlast the car.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
I am not familiar with this problem? Can somebody post a picture of the problem part?
Tsunamiboy 1979 911 SC (3.2L) 1997 Boxster 986 |
Just search " rear sway bar mount" in this forum.
