wayner's Avatar
Why do sway bar mounts tear?
Is it just cornering loads, or are the getting snagged off road?
SOLD - 914 wide body hot rod
Old 12-05-2011, 10:42 AM
Peter Zimmermann's Avatar
Stress loads from cornering. The mounts were barely good enough for o.e. bars on SCs/early Carreras, but their weakness was obvious with the bar size change in '86.
Keep the Shiny Side UP!
Pete Z.
Old 12-05-2011, 10:47 AM
MBruns for President
JeremyD's Avatar
and bigger, stickier tires...
Old 12-05-2011, 10:56 AM
wayner's Avatar
Thats what I initially thought. Reading all these threads about it had me wondering if there was some way to relocate the bar out of harms, way, but if most believe it is just the cornering loads, then I guess I am good with just beefing them up.
I can go back and tune in to that thread.
Thansk!
Old 12-05-2011, 11:07 AM
After years of metal fatigue something has to give.
Old 12-05-2011, 11:08 AM
Porsche Owner
mark4ton's Avatar
now is there a solid fix to this issue or we just have to reweld?
1987 Carrera - 2008 Cayenne Turbo
Old 12-05-2011, 01:32 PM
dshepp806's Avatar
Several "fixes" out there (even Porsche came out with a better part-"butterfly").
I have a driver side rear cracked, at present and have the WEVO's in hand to install (both sides-ahem)
It will certainly require "welding"!!!!!
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-05-2011, 01:58 PM
Thansk!
Seems like latter chassis 911s have more of an issue with broken SB mounts. They're heavier.
Sherwood
Old 12-05-2011, 02:04 PM
Platinum Member
dad911's Avatar
To me, it seems like those that stiffen the sways without stiffer shocks and springs tear out the mounts.
I had a '77 100% track use, with stiff torsion bars and custom valved struts/shocks that was fine with the stock swaybar mounts.
Old 12-05-2011, 03:14 PM
wayner's Avatar
Hmmm, that's interesting. Do you suppose that there was less force applied to the sway bar because more was taken up by the suspension?
Old 12-05-2011, 04:02 PM
dshepp806's Avatar
Look at the later car's torsion bars.....larger, no?
Doyle
Middle Georgia
Old 12-05-2011, 04:06 PM
Doyle
22mm and larger sway bars, 300+ lbs. more chassis weight and wider wheels/tracks widths play a factor. Earlier 911s typically don't carry those specs., not to say the mounts are foolproof, just adequate for most early cars.
Sherwood
Old 12-05-2011, 04:26 PM
dshepp806's Avatar
I found it interesting that Porsche acknowledged this having come out with the replacement butterfly mounts (Porsche part) (again).. even through 1989,.....These WEVO's will put an end to any further sway bar issues........
Assured, early ones didn't carry the larger sized torsion bars....
Best!
Doyle
Middle Georgia
Old 12-05-2011, 04:51 PM
ShakinJoe's Avatar
I used the Buckley rear mounts. They will outlast the car.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 12-05-2011, 04:55 PM
Tsunamiboy's Avatar
I am not familiar with this problem? Can somebody post a picture of the problem part?
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 12-05-2011, 04:59 PM
ShakinJoe's Avatar
Just search " rear sway bar mount" in this forum.
Old 12-05-2011, 05:36 PM
