Member 911 Anonymous
Okay Fellas,
3.2 Front Caliper Bleed Valves are only available from Germany PAG, kinda want not to have to wait :-( Has anyone tried to use SC valves on a 3.2? TIA, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hi Jim,
The 3.2 caliper is the same as an SC except that there is a spacer inserted between the two halves to allow for thicker discs so the bleed nipples should be the same |
Interesting, I may just give it a try. Thanks Brother English
Flat Six
Useful parts interchange summary, too: -- 'M' Front & Rear brake calipers are made of Steel and have approximately a 3 inch, center to center, bolt spacing. These were used as front calipers up until early 1975. -- 'S' Front brake calipers are made of Aluminum and have approx. a 3 1/2 inch, center to center, bolt spacing. These were used on some 911s and all 911 Turbos between 1974 and 1977. -- 'A' Front brake calipers are made of Steel and have approx. a 3 1/2 inch, center to center, bolt spacing. These were used on many mid-70s 911s and practically all 911SCs. Beginning in 1984, the Carrera used wider versions of 911SC calipers - the 'wide A' and 'wide M'.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Oh very Cool Flat Six!
Okay, if I am reading correctly: OEM Standard Bleeder Valves are: 911-351-919-01-OEM Bleeder Valve, front 'A' caliper (sold per each), 911 (late 1975-83) 911-351-919-02-OEM Bleeder Valve, front caliper (sold per each), 911 Carrera (1984-89) Then if you read the Speed Bleeder Valve Specs, it should match: Speed Bleeder Valves, "A" Front Caliper (sold per pair, one valve per caliper) Front 911 (late 1975-89) I will post my findings, Jim
When you say 3.2 bleeder, do you include my 88 bleeder too? If so, I think I have one extra, brand new. If you are ok with used, then I think I have an old one too. Let me know, I'll look for them.
Fat butt 911, 1987 Last edited by rnln; 12-06-2011 at 05:07 PM.. |
Thanks Rnln,
I actually order the front SC valve and new Carrera 3.2 84-89 rear valves, new. According to the Speed Valve Specs for their front speed valves it is for 75-89 so I am hoping the SC OEM valves will be the same OD and pitch as the 3.2 Carrera valves. Jim
ok Draco, I didn't know front and rear are different but my are front. You know where they are now if you need them quick.
Fat butt 911, 1987 |
Thanks Brother Rnln!
Update:
The answer is weird YES on my 3.2: 911-351-919-01 will fit on both Front and Rear Calipers on my '85 3.2, Does this mean POs or Retard Wrench threaded in a front bleeder valves on my rear calipers? But Why??? The spec on the 911-351-919-01 are 8MM OD thread with 9MM Hex plus Rubber Cap included ![]() ![]() Strangely enough, PAG spec calls for 901-352-977-10 on rears but it is way too small in OD to fit in the rear calipers on my 3.2 Also looking at the PAG numbers for the front 911-351-919-02 with out capHas anyone else experienced this???
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 12-09-2011 at 10:46 PM.. |
