My 2 cents worth. Check to see if the Under hood light in the back is shorting you out. My car's previous owner had cut the wires and just tucked them up into the edge of the engine hood. My second problem was to back to electrical 101, I checked with a continuity tester to see if I was getting juice across the fuse at the fuse box. I found that what looked like a good fuse was not transmitting electricity, I changed the fuse and it has been working ever since.
Old 12-21-2011, 12:54 PM
ROW '78 911 Targa
timmy2's Avatar
Originally Posted by LIVEVIL View Post
Ok So I have figured out that it's the green wire with a yellow stripe that is grounding out someplace. Where, I have no clue.
Trace and replace... or repair. (Trace and replace just sounded better)
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-21-2011, 05:25 PM
SweetWaterSurprise's Avatar
Thanks. I know the fuses, stalk, and relay are good, they are all new. Its just a ground out someplace from that wire. I still need to check some other wires mentioned in this thread. I appreciate the help.
Old 12-21-2011, 06:42 PM
ROW '78 911 Targa
timmy2's Avatar
LIVEVIL, What year is your car? Do you have the schematic wiring diagram?
The only green wire with yellow trace on my '78 to '83 diagram runs from fuse 6 bottom to the low beams.
Dennis
Old 12-21-2011, 09:51 PM
Porsche Head's Avatar
I had a similar issue when I got my car back from paint.
It was the way the bulbs were seating or the incorrect bulbs. Once sorted out there were actually no wiring issues.
As always not sure if that is your issue but hope it sheds some light
1972 911E w/3.0 RS Replica
1988 M5 300hp
2016 Audi Q5 TDI
Old 12-21-2011, 11:27 PM
Similar Issue
Same twist - with turn signals not working but emergency working however I noticed that with the vehicle turned off that I can get a solid turn signal (ie no flash/blinking).
I was wondering if that points more towards the turn signal switch being bad?
Old 12-22-2011, 11:48 AM
arbita1's Avatar
That's actually the parking light feature, and it works off a separate system. Maybe start a new post (not to hijack this one) and you can get some troubleshooting ideas.
Here are some quick ideas in the meantime:
1. Is Fuse No. 11 good? (I'm assuming you have an SC). A quick check is to see if your back up lights work as well.
2. If yes, is there power at connector no. 49 of the Turn Signal Relay socket?
3. If yes, then chances are the relay is bad and is the problem.
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-22-2011, 12:18 PM
My car is a 82. I am going to take out all my bulbs, check those connecttions and see if I am still blowing the fuse.
Old 12-23-2011, 08:11 AM
Banned
I've been having the exact same problem for a while now. I looked around for emergency lights but could only find stuff like this emergencylights.net
Can someone please help me find the right type of emergency light replacement?!
Old 05-04-2012, 03:47 PM
