Josh
Need help with MSD wiring
Hi - I have a 1975 911s that I am working to remove a rajay turbo system from. I have been documenting this in a separate thread but I wanted to post this separately to try and attract members with MSD knowledge.
The turbo system has been completely removed except for the turbo master (see first pic) that was wired into the MSD system. What I am asking is how should the MSD system be wired once the turbo master is removed, more specifically - it is the white MSD wire I am confused about.
I have the MSD (model 6200) instructions. It seems to me that the white wire from the MSD is supposed to connect to the distributor. In my second pic you will see all the wires. There is a blue wire that leads to a purple/black wire that is the tachometer wire. According to my factory wiring diagram this is also supposed to be connected to the distributor. Should I connect the blue wire and the white wire from the MSD both to the white wire leading to the distributor?
I really appreciate any help I can get. I am totally new to this and I know a few of you are getting sick of my basic questions so I apologize in advance.
Old 12-10-2011, 11:16 AM
