911SC is oxygen sensor system required to run properly? can I delete??????
I putting an 82 SC engine into a car that has the oxygen sensor removed. Do you need the oxygen sensor system? If I don't, do I just not connect it and what else do I do?
70 and 71 911s sure are easier.
thanks
Marlin
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 12-11-2011, 06:12 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Doesn't need it, but not sure what else needs to be done on the CIS system if you are keeping all the other stuff.
Gary R.
Old 12-11-2011, 06:19 AM
fred cook's Avatar
O2 Sensor....
I have run my '80 SC both with and without the oxygen sensor plugged in. It did not seem to make any difference in the fuel mileage and the engine can be made to idle better with it unplugged. If nothing else, you could use the port for a wideband sensor to feed an air/fuel ratio gauge, etc. If you are in an area that requires emissions inspections, you probably will have to leave it in place.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 12-11-2011, 08:05 AM
you absolutely need the computer, O2 relay, frequency valve and the wire loom for it to run properly. as for the O2 sensor plugged or unplugged, try it both ways and see which one you like better. or change to a 78-79 fuel distributor and WUR.
206 637 4071
Old 12-11-2011, 09:18 AM
John Walker,
thank you so much for the info. I don't have any of that now, so time to go find it.
best regards
Marlin
Marlin Ness
Old 12-11-2011, 06:14 PM
j911brick's Avatar
I found that they run better when the system is hooked up and working, but if you delete it you may need a '78-'79 ignition distributor.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 12-11-2011, 06:43 PM
